transmission syncro
Old 03-15-2007, 12:23 AM
Chewy[Ek]'s Avatar
Default transmission syncro
i did a search but there was no information about it. purpose of transmission syncro?? how will wear affect the transmission??
Old 03-15-2007, 06:47 AM
lude98SH's Avatar
Default Re: transmission syncro (Chewy[Ek])
technically the syncro is composed of the syncro sleeve and hub,blocker rings,keys, and these little springs i forget what they are called exactly. They are moved back and forth by shift forks that are controled by shift linkage. What the syncros do is slow the speed of the freewheeling gear and lock it in place to make it spin the same speed as the shaft it is on. The blocker ring does the actual slowing down of the gear and then the sleeve slides over and then locks onto the dog teeth of the gear, the syncro assembly is splined to the shaft and always spins the same speed as the shaft.
Old 03-15-2007, 10:44 AM
Chewy[Ek]'s Avatar
so what happens when the snycro gets wear down? will it grind more? or sluggish shifting??
Old 03-15-2007, 11:07 AM
Chuckles99SH's Avatar
Default Re: (Chewy[Ek])
grinds, n stuff
Old 03-15-2007, 02:58 PM
glazethatj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">technically the syncro is composed of the syncro sleeve and hub,blocker rings,keys, and these little springs i forget what they are called exactly. They are moved back and forth by shift forks that are controled by shift linkage. What the syncros do is slow the speed of the freewheeling gear and lock it in place to make it spin the same speed as the shaft it is on. The blocker ring does the actual slowing down of the gear and then the sleeve slides over and then locks onto the dog teeth of the gear, the syncro assembly is splined to the shaft and always spins the same speed as the shaft. </TD></TR></TABLE>
what he said. basically slows the gears down when you shift so they catch right and dont slip or grind
Old 03-15-2007, 05:30 PM
Chewy[Ek]'s Avatar
thanks for the informatioin
Old 03-15-2007, 05:53 PM
Rosko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chewy[Ek &raquo;</TD></TR><TR><TD CLASS="quote">]so what happens when the snycro gets wear down? will it grind more? or sluggish shifting??</TD></TR></TABLE>
then its not able to slow the "freewheeling" gear down and instead the grinding teeth will slow it down, which will cause other problems.
mn_babyboy
11-29-2007 12:59 PM
integlover
07-13-2007 01:55 AM
bluesaint
08-09-2006 06:07 AM
Chairman Kaga
11-16-2001 10:25 AM
Quick Reply: transmission syncro
