You in luck...
Old Mar 20, 2007 | 03:15 PM
WRXnomore's Avatar
Default You in luck...
My 98 Base Auto is in the shop right now. My tranny went out and I got a quote for $2400 to rebuild. I laughed....So I did some research, decided to do the swap, ordered my parts and I am getting my car back this friday. I'm an organized guy so I made a parts list. The total for these parts, down to the shift **** was $1540.00 That is actually a great price because I got some of the parts from people here on Honda-Tech. The Shop (SRD in AZ) is charging me $820 to do the swap. ($2360 total) Less then a auto rebuild...gotta love honda. O'yea, this is also including the ECU conversion. GOing from OBD2 to OBD1.
Parts:
Shifter Assembly
Pedal Assembly
Shifter Cables
Forbidden Motorsports Short Shifter
M2B4 Transmission w/LSD w/ Starter
Exedy Honda Clutch Kit
Clutch Master/Slave Cylinder
OBD1 p13 STOCK ECU FOR GSR
ECU CONVERSION JUMPER HARNESS OBD2 - OBD1
EXEDY OEM FLYWHEEL - HONDA ACCORD / PRELUDE / CL
Intermediate Shaft
Shift boot
Shift ****
Optional parts I did not get:
5spd Gauge Cluster
Trans mounts-side
Clutch Dampener
Vehicle Speed Sensor (VSS)
Reverse Switch
Shift linkage
Old Mar 20, 2007 | 03:16 PM
WRXnomore's Avatar
Default Re: You in luck... (WRXnomore) ADMIN-Delete this post
I posted this in the wrong spot, how do I move it!!!??? OR if an admin. can delete for me. THX
EF_World
Aug 31, 2011 09:18 AM
dre2day
Oct 9, 2010 12:21 PM
H22LUDE808
Nov 5, 2006 02:29 AM
jdmintegra1994
Nov 25, 2003 05:05 AM
