HID Connection help
Old Mar 13, 2007 | 10:12 AM
HS2G's Avatar
Default HID Connection help
I am trying to install an H1 into my lude and everything mounted up correct and I did connect the red + to the + battery and the Ground wire to the - Battery. I then tried to connect the + and - to the stock headlight plug and nothing turns on. Did I skip a process? Here are some pics
Old Mar 13, 2007 | 11:24 AM
Speedra500's Avatar
Default Re: HID Connection help (HS2G)
it turns on when you connect it to the battery but doesnt when its connected to the headlights?
Old Mar 13, 2007 | 11:27 AM
HS2G's Avatar
Default Re: HID Connection help (Speedra500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedra500 &raquo;</TD></TR><TR><TD CLASS="quote">it turns on when you connect it to the battery but doesnt when its connected to the headlights?</TD></TR></TABLE>
It doesn't turn on at all. I connected everything up but doesn't see like its getting any power. I dont know whats wrong. I thought it was my fuse but I checked and they look fine. Does anyone know whats the deal?
Old Mar 13, 2007 | 11:37 AM
redtop22's Avatar
maybe your ballasts are fubar? what kind of kit did you get, i thought they usually come with pnp harness adapters so you dont have to bother with all that wiring?
Old Mar 13, 2007 | 11:45 AM
HS2G's Avatar
Default Re: (redtop22)
I got the kit thats in the Misc. and appearrance section right now for 140 shipped. Everyone had goods things to say about it so it seems to be a pretty good kit. It still is a good kit I probably messed up on the wiring.
Does anyone know where I can find a write up on how to install them.
Old Mar 13, 2007 | 01:32 PM
HS2G's Avatar
Default Re: (HS2G)
Bump...
Anyone know whats wrong?
Old Mar 13, 2007 | 02:09 PM
Speedra500's Avatar
Default Re: (HS2G)
if you connect it to the battery and it does not turn on something is wrong
Old Mar 13, 2007 | 02:11 PM
spin_r_g's Avatar
Should be a simple wiring mistake but can't tell how your kit is hooked up from those pictures.
Misty Taylor
Honda Civic (2001 - 2005)
Aug 28, 2019 11:38 AM
dagle
Honda S2000
12
Feb 17, 2008 07:54 PM
uneek4dr
Feb 21, 2006 07:41 PM
gvc3k
Oct 5, 2004 01:02 PM
tallblondkid
15
Jan 26, 2004 07:28 AM
