test pipe..
Old Mar 13, 2007 | 05:20 PM
preludefien
Guest
Posts: n/a
Default test pipe..
i have searched this already. on the 95 prelude when i replace the cat converter with a high flow car or test pipe will it pass inspections. thanks
Old Mar 13, 2007 | 05:25 PM
Flip.'s Avatar
Default Re: test pipe.. (preludefien)
Hiflow cat - yes
test pipe - no
also depends on other mods, what sort of test it is etc...
Old Mar 13, 2007 | 05:33 PM
SnoMan's Avatar
you can buy a blox MIL eliminator from inlinefour.com, it's a little plug that goes into your test pipe putting some space between the exhaust flow and the o2 sensor. I made a homeade plug and it worked fine, passed emissions with a test pipe n everything...
Old Mar 13, 2007 | 06:08 PM
preludefien
Guest
Posts: n/a
Default Re: test pipe.. (Flip01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flip01 &raquo;</TD></TR><TR><TD CLASS="quote">Hiflow cat - yes
test pipe - no
is this so...ive heard that a test pipe will pass i just want someone to confirm...
Old Mar 13, 2007 | 06:48 PM
TheWalrus's Avatar
a hiflow will pass, but a test pipe will not pass on a obd1 car, because the emission test is different. for obd1 they run it on a dyno with a sniffer in the muffler to actually read what the car is producing...on obd2 they just plug in a connector under the dash and read what the ecu is telling it. so if the ecu doesnt know anything is wrong, the car will pass.
jdmisoverrated
Jan 31, 2008 07:54 AM
youre_scum
Jun 26, 2006 09:45 PM
renegadez7o7
Sep 9, 2005 07:03 PM
ramz7887
Aug 17, 2003 10:22 AM
