ABS system removal.
ABS system removal.
so i went through all the threads from the prelude forum and i did not see a write up for ABS system removal. jus wondering if i missed it or if there isnt one.
if there none can anyone tell me teh basics on it. the main things i need to do. i have a slight clue but i need reassurance b4 i do it.
thanx for ur help and hope this doesnt get bashed
1 Post
Re: ABS system removal. (MacONE)
Official how to remove ABS thread: https://honda-tech.com/zerothread?id=1347569
Just use the search button under archived threads.
Re: ABS system removal. (Hawkze_2.3)
thanx, i went through all 8 pages and did not find it, nexx tim ei will use that infamous search button.
thanx
thanx
On the 5th gen do you have to remove the lines to the rear also because it is 4 wheel abs. Also i am alittle unclear about where the proportioning valve is located ? Would running the prelude s brake booster help or hurt braking ? And lastly can you leave the abs axles ??
cutting the lines makes up for a lot of time. also all you need to do to remove the brake booster is remove the IAT sensor. it comes out easily if you turn it the right direction. a hard part is finding the bolts that hold the abs unit on without being able to see them. any questions, PM me.
