Need Help Please
Old Dec 4, 2008 | 09:15 PM
smile_78905's Avatar
Icon3 Need Help Please
Hey guys new here and was referred by a friend, but have a question? I just bought a 98 honda prelude and its leaking water from somewhere.. the back seats are wet and the carpet in the back always gets wet. Everytime it rains it happens and since its wet moisture keeps buildings in the inside of the glass. Does anyone know what the problem might be cus its driving me crazy and it smells?! Please Help Thanks
Old Dec 5, 2008 | 05:18 AM
duceducecord's Avatar
Have you checked for holes around your car? And check your moon roof for cracks around the seal. That's the onky thing I can think of
Old Dec 5, 2008 | 10:10 AM
Tweaked's Avatar
What I would do is get in your car while someone sprays your car with water at every angle to check where the leak is coming from.
Old Dec 5, 2008 | 10:16 AM
ezra76's Avatar
Check around the rear window as well. The plastic panels come off easy. You'll see that a leak there would run right down beside the seats and to the floor. If that window has been replaced, someone might have done a halfa$$ job on it.
Old Dec 5, 2008 | 01:58 PM
Rkwan87's Avatar
if you cannot find out where it is coming from check spare tire if you are leaking water there should be a puddle in there and there should be rubber seals in there pop those out to get the puddle to drain
what happen for some reason is that water gets into that area with the spare tire and when you drive i believe water sloshes and wets your back seats
Old Dec 6, 2008 | 11:03 AM
Crash_Control's Avatar
I would suspect your sun roof drain tubes are plugged or have come off the sun roof assembly or the tubes have broken.
You will be able to see the connections when you take the plastic headliner off thats just in front of the rear window.
There are four sunroof drains one in each corner of the roof.
Old Dec 6, 2008 | 06:34 PM
duanes's Avatar
Hmmm - I had an old dodge truck that did that. The problem was not the windows but plugs under the carpet. In many cars, they are in the floor board or under the seats. I don't know if Honda does this or not, but many mfg's do.
But if the rear seats are getting wet - is it the seat part, the upright part, how far up? Given what you have checked, the only thing I can think of would be water getting into the trunk or spare tire area and sloshing forward during braking. (Like RKwan87 suggests)
Try removing the rear seats and going to the car wash.
07AccordBC
May 4, 2012 12:13 AM
low430
May 18, 2005 10:34 PM
fattymatty
Jan 2, 2005 07:44 PM
charlieway
Apr 30, 2004 03:23 PM
8alaRm
Jan 9, 2003 08:24 AM
