Front engine mount
Old Dec 8, 2008 | 10:21 AM
h23prelude94's Avatar
Icon6 Front engine mount
Hi i have a 4th gne with the h23 in it....if the mount starts to go which i think it is if i come to a stop in first gear the engine will jerk even if im not touching the gas if i dont replace it right away will it break off entirely?
Old Dec 8, 2008 | 10:43 AM
vinuneuro's Avatar
Eventually maybe. The front mount doesn't do anything statically. It's only in play when you're shifting, getting off the throttle etc. It's easy enough to get to that I'd just pull it and inspect.
Old Dec 8, 2008 | 11:20 AM
viper_boy403's Avatar
The rear motor mount is usually the culprit in instances like this. It's hard to get at though, so check the front one first like already suggested. IF it's torn or worn, you can easily replace it or just get a set of energy suspension motor mount inserts to stiffen it up a bit.
Old Dec 8, 2008 | 04:13 PM
lude98SH's Avatar
with the ES insert you gotta be ready for the rattling that may occur at idle. Although those ES inserts did help alot with wheel hop.
Old Dec 8, 2008 | 04:49 PM
True, but if he only uses the front one it doesn't really have any vibrations. The back one is killer though lol
Old Dec 8, 2008 | 07:21 PM
duanes's Avatar
To really answer the question - the front mount isn't going to break - it is a square piece of steel that completely encircles the bolt assembly that attaches the motor.
However - mine was (is broken) and the vibration was quite noticeable. But, when I got the car, there was a bolt missing (1 of 2 bolts) on the driver side mount and the motor vibrated so badly that the front bumper was about to fall off. - Absolutely terrible ! - Side mount is now fixed and I agree with previous posts. Some vibration but not nearly as bad as two mounts with problems.
Old Dec 9, 2008 | 07:18 AM
G2IntegraGS's Avatar
Innovative mounts FTW
Old Dec 9, 2008 | 10:19 AM
ok thanks guys
bunske123
Oct 10, 2007 10:50 PM
mattL
May 25, 2004 12:32 PM
Tire Monkey
May 1, 2004 12:38 PM
Neldawg
Jan 13, 2004 08:53 PM
balistic CRX
Dec 27, 2001 04:37 AM
