Starter Problem?
Old Dec 15, 2008 | 11:00 PM
Inextricabledrvr's Avatar
Default Starter Problem?
1997 SH
Heres my situation:
1.) Car would not start
2.) Changed positive battery terminal due to corrision and stripped bolt (Did not solve problem)
3.) Checked battery at autozone and came out a "good battery"
4.) Headlights, horn, internal instrument lights work perfectly fine
My car had a "single click" when I would try to start the car and would not crank..
THEN
The click went away and there is no sound and still will not crank over
I am assuming its the starter because if the alternator was bad then the battery would've been low. Someone correct me if im wrong. I just want to make sure there isnt anything else I should do before I take it all apart.
Thanks guys!
Old Dec 16, 2008 | 10:16 AM
h23prelude94's Avatar
check the alternator to be sure....cna you jump start it....cause i had a problem similar to yours....i had power to everything and it wouldnt crank....even when we jumped it....it was cause the engine was ceased haha....but will it run if you Jump it?
Old Dec 16, 2008 | 03:37 PM
Kronn 98SH's Avatar
Just push-start the car and see what happens.
Old Dec 16, 2008 | 03:42 PM
mattsnooz's Avatar
smack the starter solinoid with a hammer (preferably a rubber mallet) while someone is trying to start it. Your solinoid could be sticking which sends power to your starter (gear motor) to mechanically spin your fly wheel ( I think anyway, thats my inturpretation of what I've read)
Old Dec 16, 2008 | 03:44 PM
Kronn 98SH's Avatar
A hung/stuck starter (solenoid) is a common problem. Push-starting will help diagnose it.
Old Dec 16, 2008 | 03:48 PM
H9Omega's Avatar
Some of the technial analysis on this forum have really went downhill, OP did a great job explaining te situation, obviously the starter is not clicking, first thing to check would be if the starter is even getting a signal, once you determine if the starter is getting power (check the fuse), if it is than your starter is shot.If not pop in a new fuse and you should be good to go.
Old Dec 16, 2008 | 03:50 PM
mattsnooz's Avatar
wtf...I just noticed with my front end jacked and on stands even in neutral the front tires have a frontward rolling motion while the motor is running! Is that normal? I figured in neutral gear, no mechanical connection from the motor to the drivetrain should exist?
or is this how a rolling start works??
Old Dec 16, 2008 | 03:53 PM
mattsnooz's Avatar
who you talking about in particular h90mgea?
If the starter itself isn't making any clicking noise than the solenoid that sends power to it to make it attempt to rotate, could be stuck. If you apply a bit of an impact to it, it will loosen the solenoid allowing it to close, feeding power to the starter? yes no?
Old Dec 16, 2008 | 04:48 PM
mafia's Avatar
Dono if you have auto zone handy or some place like that, but if u take ur starter and take it there theyll tell u if its bad.
Old Dec 17, 2008 | 08:33 AM
Push start worked with no problems...
Old Dec 17, 2008 | 08:34 AM
I did this a couple time and it cranked over, but after the 3rd time the car was a no go...
Old Dec 17, 2008 | 08:36 AM
Finally, I removed the starter and did brought it to AUTOZONE and they said the starter is done. So I went ahead and purchased a new starter from them with a lifetime warranty.
And problem solved! Car started right up with no hesitations!
Thank you to everyone for their input I greatly appreciate it...
Old Dec 17, 2008 | 09:24 PM
Kronn 98SH's Avatar
So, just to clarify: Push start worked, tapping the starter to unhang it worked, so had it tested at AutoZone and it was bad. Not a blown fuse? Yep, sounds like some ****-poor technical analysis to me. Dolt.
Old Dec 18, 2008 | 03:43 AM
G2IntegraGS's Avatar
It could have also been the "signal" wire. Its pretty uncommon for honda starters to go bad.
Old Dec 18, 2008 | 04:33 AM
kulrevon's Avatar
It's not uncommon for honda starters to go bad. They are a wear item so they go bad after time or after use.
HI91EFHB
Nov 1, 2009 06:46 PM
cilvia
Jul 31, 2008 05:34 AM
incognito E46
May 30, 2005 05:06 PM
mrcch
Sep 15, 2004 08:39 PM
kaoss_11
Aug 28, 2004 04:36 PM
