Compression test #'s okay?
Old Aug 23, 2002 | 08:52 AM
satan_srv's Avatar
Default Compression test #'s okay?
175 175 150 175
This was done with a extremely cold car...been sitting for 3 days...okay? 96 VTEC 100,000 miles...
Old Aug 23, 2002 | 08:54 AM
LudeBehavior's Avatar
New User
Default Re: Compression test #'s okay? (satan_srv)
looks pretty good except for the 150?? as long as they are around 180 and within 10pts of each other...
Old Aug 23, 2002 | 09:00 AM
satan_srv's Avatar
Default Re: Compression test #'s okay? (LudeBehavior)
I think they will test it again once they get the timing belt on and the car running...
Old Aug 23, 2002 | 09:09 AM
Firedrake's Avatar
Yah, that 150 is a little low
Brian
Old Aug 23, 2002 | 09:22 AM
satan_srv's Avatar
That's 14% out...10% is normal??
Old Aug 23, 2002 | 09:28 AM
Flavour's Avatar
i thought it was 10psi was acceptable, rather than 10%... i mean your car will still work... but it would be unsuitable for nos, thats for sure...
Old Aug 23, 2002 | 09:57 AM
Mike95lude's Avatar
Those are a hell of a lot lower than mine. Test it when your engine is still warm, that's when you are supossed to do it. I got: 225, 225, 230, 235 last time I did it. Stock compression.
Old Aug 23, 2002 | 10:03 AM
satan_srv's Avatar
Default Re: Compression test #'s okay? (Mike95lude)
That's ridicuously high...are your cylinders full of carbon??
Old Aug 23, 2002 | 11:00 AM
Mike95lude's Avatar
Probably
But my H22 runs strong. Since my car is totalled I'll be pulling the motor and rebuilding it for NA, then I can check.
Old Aug 24, 2002 | 10:29 AM
satan_srv's Avatar
Actually my numbers were 175 165 175 170 so that's better
Old Aug 25, 2002 | 12:24 AM
aeolus's Avatar
Probably
those high compression numbers have to be from a jdm motor,i used to have one and they were well within that range.A usdm,10.0:1 compression one should be around 200-210 or so.
Old Aug 25, 2002 | 12:50 PM
Mover's Avatar
Default Re: Compression test #'s okay? (aeolus)
Those are my numbers
Old Aug 25, 2002 | 12:56 PM
Mike95lude's Avatar
Its a USDM H22A1. My friend did a compression test on his 94 B18C1 the same day and got numbers in the 230 range too, stock compression. Are you guys cranking the motor over and over until the compression reading STOPS going up? If not, then that could explain the difference. Plus do it when your engine isn't dead cold.
Old Aug 27, 2002 | 07:07 AM
Screaming Vtec's Avatar
Well ive just come back from the dyno, and before I put the lude on the rollers, I asked them to check compression...
Numbers came back as 260-265!!!
He asked me what compression the engine is at he said those numbers are what he'd expect from an 11:1 compression engine, whereas mines only supposed to be 10:6:1
Car is JDM VTEC
Just had my VAFC set up on the rollers, gained 10.6 bhp peak!
Well chuffed..
Mods are Kakimoto racing catback
Home made CAI
VAFC.
Leads and plugs
Base run was 170.2 whp @ 6979,
Came out with 181.8 @ 7102
Old Aug 27, 2002 | 07:09 AM
Oh yeah it was a 'wet test' and the engine was still pretty warm
Old Aug 27, 2002 | 09:34 AM
Mover's Avatar
Default Re: Compression test #'s okay? (Screaming Vtec)
Have you done a dry test ??
I'd guess .. 30 psi down from your 'wet test'... but I could be wrong
liquidzorch
Sep 13, 2013 07:33 PM
Dark_Teg
Oct 15, 2009 07:56 PM
boosted440
Jan 28, 2006 04:19 AM
Built2.0Lude
Aug 19, 2003 10:20 AM
