Broken Wheel Studs
Old Aug 19, 2002 | 07:32 PM
Jordan_4WS's Avatar
New User
Default Broken Wheel Studs
I had 3 lug nuts on my wheel, cause 1 is stripped. Anyway somehow today 2 of the studs broke, leaving me one 1 good stud. I have to replace them tomorrow, but has anyone ever seen thsi happen? What coudl cause a wheel stud to snap off - I have always torqed them to 80 ft/lbs. Also how do I go about in replacing them? How involved is the replacement and how much would a shop charge if I was too lazy to do it myself?
Jordan
Old Aug 19, 2002 | 10:11 PM
PrecisionH23a's Avatar
Default Re: Broken Wheel Studs (Jordan_4WS)
usually they snap off due to being overtorqued, shitty lug nuts, or abuse. Youll have to remove the wheel, caliper, rotor, then separate the upper control arm as well as the lower and once you have everything separated take it to a shop that can press new studs in them, i recommend replacing all 4 while you're at it.
Old Aug 19, 2002 | 10:12 PM
ShowSpeed's Avatar
replacing a stud is not-so-fun. you have to take off your rotor.. and sorta the assembly behind it.. you'll basically have to press(ghetto: hammer).. the studs out. To put the studs back in.. you'll have to take it to a shop (Midas, muffler shop..etc).. that has a machine press. They can press it in for you.. (bout 5-10 bucks.. try to do it on the side.. and just slip the guy some cash)
Old Aug 20, 2002 | 12:11 AM
Jordan_4WS's Avatar
New User
Default Re: Broken Wheel Studs (ShowSpeed)
What is involed in taking the hub (thats the thing that hold the 4 studs in and attaches the wheel bearing, right) off? Wiill I have to remove the whole knuckle or will it just slide off? Can everything aside from the presing of the studs be done with hand-tools or do I need anything special? Do I have to remove the lower and uppercontrols arm, and do I have to pull the ball joints for each?
Jordan
Old Aug 20, 2002 | 05:53 AM
aklucsarits's Avatar
New User
That's why the stud broke.
Andrew
88 EF Hatch
Oct 15, 2009 09:33 PM
deez nuts
Jun 10, 2004 10:39 PM
Ninjaboi_on_X
Mar 16, 2003 07:14 PM
JLange
Feb 8, 2003 02:14 PM
dynamo
Sep 20, 2002 11:37 AM
