Cold engine problems!
Old Aug 21, 2002 | 10:34 PM
Speedy Gonzalez's Avatar
Default Cold engine problems!
Well every time I start my car in the morning, the idle will surge for a little while (from 1,000 rpm to 2,000 rpm) and then the engine will shut down. Then I have to start and rev it up until the engine is warm if not it will keep stalling. The problem goes away when it reach the operating temperature. At first I thought it was the ecu because I used a Spoon program (you know, racing parameters...), but now I'm using the original OBD-1 JDM P13 but the problem still there, also I noticed the car lost power (I guess the Spoon program works) so I will installed as soon as possible. I check all the vacuum lines, next the TPS. Any suggestions! (It a pain to wake all my neighbors )
Also I was using a Field Vtec SFC controller but that piece of sh** don't work anymore. When I try to use it, the car won't rev past 6,500 rpm (in any gear) It **** me off. I don't know if I’m use to the car now but if feels slower. I check the compression but is good (255,252,255,247) so I’m just going to keep digging.
Right now I don't have the EGR connected, how can I fool the ECU so that it stops throwing codes at me? (code 12) Any help with the surging and EGR will be greatly appreciated!
Old Aug 22, 2002 | 06:12 PM
Default Re: Cold engine problems! (Speedy Gonzalez)
Anyone?
captain_sl0w
Jul 17, 2008 10:03 AM
KOVENANT
Oct 4, 2004 01:09 AM
Mike813
Jun 8, 2004 04:58 PM
blackedoutcivic
May 9, 2003 05:39 AM
Batoutahell
May 7, 2003 04:26 AM
