Open deck or closed
Old Apr 1, 2003 | 01:36 PM
Riptide101's Avatar
Default Open deck or closed
Is a Jdm H22a open deck or closed. I tried using the search fuction but it never works
Old Apr 1, 2003 | 01:58 PM
Shakes's Avatar
space cadet
Default Re: Open deck or closed (Riptide101)
i believe it is open deck like the usdm.
Old Apr 1, 2003 | 02:29 PM
lewd43's Avatar
Default Re: Open deck or closed (shakes)
i've read different, just cant remeber where. anyone with a jdm motor want to verify whether its closed deck or open deck?
Old Apr 1, 2003 | 02:41 PM
Riptide101's Avatar
Default Re: Open deck or closed (lewd43)
I could have sworn that someone said 97 2001 was open and before that was closed but I'm not sure. Thats why I'm asking you guys.
Old Apr 1, 2003 | 02:59 PM
2.3vtec's Avatar
I have a 93 jdm and it is closed deck. I believe they were all closed deck up to 95
sslude's Avatar
Default Re: Open deck or closed (2.3vtec)
pretty sure its an open deck
Old Apr 1, 2003 | 03:07 PM
4bidden's Avatar
Default Re: Open deck or closed (sslude)
Closed.
Old Apr 1, 2003 | 03:08 PM
Riptide101's Avatar
Default Re: Open deck or closed (4bidden)
This is confusing. Everyone contridicts everyone.
I ask becuase I am buying some darton sleeves on groupbuy****** and when you go to check out it asks you a couple questions and one of them is open or closed deck. Also it gives the choice between long and short sleeves. Which one am I supposed to pick.
[Modified by Riptide101, 12:10 AM 4/2/2003]
Old Apr 1, 2003 | 03:14 PM
buh_buh's Avatar
H22a1 = closed deck
H22a4 = open deck
I believe this is the same for USDM and JDM spec.
Old Apr 1, 2003 | 06:14 PM
ApexiAccord's Avatar
Default Re: Open deck or closed (buh_buh)
anything from 91-95 is closed deck Jap spec or USdm
anything from 96-00 is open deck jap or usdm.
also the japspec heads has dual springs on the intake side unlike the usdm. which is only single spring.
Old Apr 1, 2003 | 06:44 PM
LudeyKrus's Avatar
H22a1 = closed deck
H22a4 = open deck
True dat!
Old Apr 1, 2003 | 06:49 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Open deck or closed (LudeyKrus)
H22a1 = closed deck
H22a4 = open deck
True dat!
JDM engines are typically just H22A, but i oudl think that they would be the same as the USDM, 92-96 are closed, and 97-01 is open
Old Apr 2, 2003 | 12:01 AM
ichibanjap's Avatar
Default Re: Open deck or closed (EX-Boosted97Lude)
The jdm and usdm 92-95 h22a are closed deck and 96-up are open. I have a 95 h22a and it's closed deck. The only thing i think people are not too sure about is if the 96 is open or closed.
Old Apr 2, 2003 | 01:12 AM
4bidden's Avatar
Default Re: Open deck or closed (ichibanjap)
96 is closed. All H22A1 are closed.
Old Apr 2, 2003 | 02:46 AM
visual's Avatar
what do u mean by deck?
Old Apr 2, 2003 | 04:45 AM
Riptide101's Avatar
Default Re: Open deck or closed (visualvb)
Sweet. Thanks guys.
Old Apr 3, 2003 | 06:21 AM
Boostless97Lude
Guest
Posts: n/a
for reference, this is an open deck from my 97 H22A4 Prelude engine
and the deck is the top of the block
Old Apr 3, 2003 | 08:44 AM
visual's Avatar
Default Re: Open deck or closed (Boosted97Lude)
thanks for the visual Sam.
Old Apr 3, 2003 | 08:45 AM
Boostless97Lude
Guest
Posts: n/a
not a problem, i knew i had that pic somewhere
Old Apr 3, 2003 | 09:52 AM
99_SH's Avatar
I think all JDM H22's are closed deck. But I may be wrong.
Old Apr 3, 2003 | 10:05 AM
vtecfiendsh's Avatar
Default Re: Open deck or closed (99_SH)
does anyone have a pic of a closed deck block just for visual comparison? i knew what the definition of both was from hearing people talk about it, but i had not seen a closed deck h22 before because i have a 98
Old Apr 11, 2003 | 06:01 PM
S14HybridHatch's Avatar
Default Re: Open deck or closed (vtecfiendsh)
now i have the 94 jdm h22a and it IS closed,( obd1 closed, obd 2 open), i was wondering can you still sleeve it, and is it different than sleeving an open deck?
purposebuilt
Jun 22, 2019 09:54 PM
High Reved Racing
Jun 10, 2008 12:08 PM
marko_think
May 25, 2004 12:31 AM
emwavey
28
Apr 17, 2004 07:55 PM
prelittlelude
Dec 27, 2003 09:39 PM
