Camber kit install problems...
Old Apr 2, 2003 | 07:06 PM
skrewdlude's Avatar
Default Camber kit install problems...
Hey guys,
I just installed my camber kit (ingalls 3570) I go to lower my car, and my control arm is hitting my inner fender well. Anyone else have this problem? The fender well sits on the control arm...Anyone?
Thanks,
Josh
Old Apr 2, 2003 | 08:34 PM
skrewdlude's Avatar
Default Re: Camber kit install problems... (skrewdlude)
come on some one has to have had this prob...did you guys just cut your inner fender piece?
Josh
Old Apr 2, 2003 | 08:47 PM
Elkins911's Avatar
your doing something wrong. your controll arm usually doesnt move when you lower your car.... wel it does, but not enough to hit your well.... my advice, start over....
Old Apr 2, 2003 | 08:57 PM
skrewdlude's Avatar
Default Re: Camber kit install problems... (Elkins911)
its not from lowering it...its from the camber kit pushing the control arm out...thusly adjusting camber
It is very common for it to hit and I was just wondering what you guys did about it.
Josh
Old Apr 3, 2003 | 08:02 AM
Elkins911's Avatar
ive had 4 lowered cars so far... and i have never experienced or heard of that happening. did you install the camber kit on backwards?
Old Apr 3, 2003 | 08:13 AM
RAB's Avatar
RAB
Foget dah bout the camber kit take it off and get better cornering capabilities.
Negative camber is a good thing not bad
Old Apr 3, 2003 | 08:41 AM
Xlerate9's Avatar
Default Re: Camber kit install problems... (RAB)
Well to a certain extent. It depends how much you lowered it. If it's slightly negative... yes it will help with cornering and you won't see terrible tire wear... but if you are riding around like this / \ then not all of your tire is making good contact with the road so it will hurt cornering and it will chew the crap out of your tires. If you went with just a sport drop you can prob get away without them. But if you went with a race drop or coilovers that you slammed the whole way down.. you def. need them. As far as them making your control arm hit the fender... it sounds to me like something was installed wrong... it shouldn't push them out THAT far... I would start over and see what you did wrong.
Old Apr 3, 2003 | 03:48 PM
skrewdlude's Avatar
Default Re: Camber kit install problems... (Xlerate9)
hey,
na it is installed correct I know this for a fact...apparently this is common with the ingalls 1 degree to 3 degree adjustable kit. I have several friends with ludes that had the same probs. Whether it was installed by a shop or not. You can not adjust it all the way. What I had to do was push the kit back so that it was giving as little correction as possible, and it just barly cleared the piece that it was hitting. My camber is in spec now, but not that it cleared the part it was hitting it can adjust a bit more.
Josh
Old Apr 3, 2003 | 06:00 PM
del_parker's Avatar
is it hitting metal or the plastic? mine rubbed the plastic a little bit, but i've removed it now, so i'm not having that problem anymore.
Old Apr 5, 2003 | 09:00 AM
spankey167's Avatar
Default Re: Camber kit install problems... (del_parker)
I had my inner fender wall shaved... thats the best bet bvut if u leave it for too long your control will break... thats what happened to my friend when he lagged on it... so do it quick...
Old Apr 5, 2003 | 10:33 AM
viperguy's Avatar
Default Re: Camber kit install problems... (spankey167)
I think I know what your problem is. When installing a camber kit, there's only certain point that you can adjust it till it hits that welded wheel well area. No mater if a camber kit says it can be adjust from 1 to 4 degrees, you can only go so much till these parts meet. My camber say it can be adjust from 1 to 3 degrees but all I can pull out of it is 1.75. If I go any further, it'll hit the welded part on top of my upper a arm. If this is what your problem is, here is a way to corrects it. Losen the balljoint form the control arm and upper a arm so that the a arm move freely. Move the a arm up and down and see how much clearence you have. Adjust the camber to the point that it almost hit the weld part but still enough to free it. Hope this help.
Old Apr 6, 2003 | 07:37 AM
luderacer's Avatar
Well i think theres 2 different models of ingalls camber kit for the lude(correct me if im wrong). Anyway I forgot the model of my camber kit. I think the camber kit i have is if your car is lowered more than 3 inches and then they have what you have lowered between 1-3inches. Anyway I have no problems with my camber kit. No rubbing at all. I'll try to see if I can find out what model my kit is.
Edit: Opps...i didnt see you have a 4th gen. I am talking about my 5th gen. Anyway if it would help you or anyone else, the ingalls part#35580
[Modified by luderacer22, 4:43 PM 4/6/2003]
superhatchbackbros
Mar 20, 2007 01:43 PM
xla301
Apr 4, 2005 11:58 PM
Sandor
Nov 17, 2003 09:01 AM
AcCorD 9dfive
Aug 17, 2003 05:53 PM
91sihatchback
10
Jul 28, 2003 09:45 PM
