Compression test: low #'s
Old May 28, 2003 | 09:35 PM
HondaUser's Avatar
Default Compression test: low #'s
I did a compression test today on my 01 base. I did it because at idle the engine makes a click-click sound. It became more noticable when i put on Skunk2 cam-gears. Well my reading was (left to right) 180 - 150 - 170 - 150. I did a search and found that most people were running 210-240 constant. A weird thing i notice was on the 150 it made a pop at the end. I did it again but it didn't poped. Do these #'s look right???
Old May 29, 2003 | 01:41 AM
musclefella's Avatar
Default Re: Compression test: low #'s (HondaUser)
Yeah two cilinders are a bit on the low site. Any blue smoke coming from the exhaust?
You can test it another way to. Start your engine and let it idle, pull the first(from left to right) sparkplugcap in the engine, the car should idle much lower for a short while,(Put the plugcap back when done and proceed to next plug) do this with every sparkplugcap, If you have lower compression in a cilinder the car will idle noticebly "higher" instead of lower like the other cilinders.
I think your piston rings are ready for replacement, take a leak test at a garage somewhere to and make sure what it is.
You can still drive your car with those readings, but the car will perform alot better with the normal compression ofcourse.
Old May 29, 2003 | 05:54 AM
SMOOTH97LUDE's Avatar
true bad compression. i had my 97 tested it has 210's on all 4. do the leak down. make sure to check your valves also.
Old May 29, 2003 | 05:56 AM
also make sure your cam gears are at 0 deg and 0 deg. you might get false compression readings if not.
Old May 29, 2003 | 06:08 AM
PrecisionH23a's Avatar
did you notice the problem after the cam gears were installed? Your timing belt may be off by a tooth...
Old May 29, 2003 | 06:17 AM
rjr162's Avatar
Default Re: Compression test: low #'s (GudeH23a)
also make sure you aren't using one of those push in compression testors... they suck. Get the screw in type so you can be sure you're not the reason the test is loosing compression
Old May 29, 2003 | 10:18 AM
ophdehEEzY
Guest
Posts: n/a
Default Re: Compression test: low #'s (rjr162)
I still havent tested my compression. I'm scared, I think a compression test is like finding out if you have HIV or not.
Old May 29, 2003 | 11:19 AM
specialque's Avatar
Default Re: Compression test: low #'s (ophdeheezy)
i guess that's one way to look at it
Old May 29, 2003 | 03:56 PM
LudeyKrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ophdeheezy &raquo;</TD></TR><TR><TD CLASS="quote">I still havent tested my compression. I'm scared, I think a compression test is like finding out if you have HIV or not. </TD></TR></TABLE>
lol....
Anyone know what GOOD numbers are for a H23?
Old May 29, 2003 | 07:21 PM
HondaUser's Avatar
Default Re: Compression test: low #'s (musclefella)
Well theres no blue smoke. just smoke when its cold, normal i guess. I don't think i need new rings, car only has 19,000 miles on it. I first heard the clicking the next day after a night when i was redlining on top of 3rd gear and i ATTEMPTED to shift into 4th but accidently went into 2nd . Some say i bent a valve or need them adjusted, others just ignore me.
Old May 29, 2003 | 07:25 PM
HondaUser's Avatar
the click sound just got louder a bit. they're also both set at 0 degrees. also i used the screw in compression test.
disease0905
Sep 13, 2013 05:04 AM
vtechjunkie
Apr 20, 2010 05:52 AM
gisserhatch
Apr 28, 2006 07:35 AM
goose21
May 17, 2005 10:57 AM
98lude
Jul 27, 2001 07:29 PM
