Advancing timing
Old Jun 2, 2003 | 11:24 AM
fe519's Avatar
Default Advancing timing
I need some help on my 4g si. A mechanic helped me before to advance my timing by 2 degrees and I need to get the car smogged so i need to adjust it back to normal. Do you turn the cap or the whole housing. Basically, the cap is black and the housing is silver, which one do you actually turn? thanks.
Old Jun 2, 2003 | 11:29 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Advancing timing (fe519)
the whole distrbutor needs to be turned, it use 2 12mm bolts, loosen them and turn it, but if you don't have a timing light, save yourself the trouble and take it to someone that does
Old Jun 2, 2003 | 01:16 PM
Cottonwoodz's Avatar
Default Re: Advancing timing (Boosted97Lude)
3, 12mm bolts
Old Jun 2, 2003 | 03:50 PM
Que_Lude's Avatar
You should make a mark (line) on your distributor and on the head so you just need to align them to be back at 15*
Old Jun 2, 2003 | 04:40 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Advancing timing (Cottonwoodz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz &raquo;</TD></TR><TR><TD CLASS="quote">3, 12mm bolts </TD></TR></TABLE>
nah, i just use 2, speed bolts mang, saves time when adjusting the timing
Old Jun 2, 2003 | 06:44 PM
fe519's Avatar
how do you know its 2 degrees advanced? should there be a setting on the timing gun? thanks and sorry for the idiodic questions
Old Jun 2, 2003 | 07:13 PM
GORBI's Avatar
Old Jun 2, 2003 | 07:16 PM
GORBI's Avatar
You guy's could tell me if I could advance my Timing in a 5th Gen Lude?
Old Jun 2, 2003 | 07:42 PM
93ludeSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fe519 &raquo;</TD></TR><TR><TD CLASS="quote">how do you know its 2 degrees advanced? should there be a setting on the timing gun? thanks and sorry for the idiodic questions</TD></TR></TABLE>
you shoot the gun at the flywheel through a hole, there are timing marks there that you use
R.A.T.
Sep 26, 2007 01:41 PM
Slammed Ek9
Apr 28, 2005 08:41 AM
turbo-d
Mar 18, 2005 08:52 PM
rideblitz
Oct 18, 2004 06:30 AM
rb26dett
Apr 8, 2002 03:43 PM
