91 Prelude Cooling fan
So ive got a 91 prelude, very nice. One problem: when the ignition is turned foward, this is the key, the cooling fan shuts off. The temp sensors are working fine because if you let the car run untill it gets to the point that the fan should turn on and then turn the car off, the fan turns on. But then when you turn the key foward, the fan shuts off. Fan will not start with car running. For now I hard wired in a switch and just watch the temp gauge. ANY IDEAS??
