Unknown sensor on h22a
Old Jan 21, 2004 | 09:26 PM
9deuce9rr's Avatar
Default Unknown sensor on h22a
Hey, i'm kinda desperate for an answer on this, but on the H22A... on top of the plastic casing for all the injector wires, there is a black cylinder with a vacuum going into it and a hose going out of it into the intake mannifold. I was wondering if anybody could let me know what that is called and what the plug in it is and if it is necessary? thanks a lot!
Modified by WhiteLude at 12:20 AM 1/23/2004
Old Jan 21, 2004 | 10:27 PM
sharkcohen's Avatar
Default Re: Unknown sensor on h22a (WhiteLude)
Sounds like the idle air control valve. Yes, you need it.
Old Jan 21, 2004 | 10:38 PM
9deuce9rr's Avatar
Default Re: Unknown sensor on h22a (sharkcohen)
where is it at on an '92 H23 ?
Old Jan 21, 2004 | 11:12 PM
Zimmlude's Avatar
If this is a JDM H22A and not actually mounted to the manifold then that is not needed. It is for the bypass butterflies in the resonator. The USDM 'ludes have the control down near the battery.
You can take it off, just be sure to plug the vacuum lines.
Old Jan 21, 2004 | 11:36 PM
dankbudz11357's Avatar
Default Re: (Zimmlude)
pics would really help
Old Jan 22, 2004 | 03:14 PM
sharkcohen's Avatar
Default Re: (dankbudz11357)
Ok, the pic makes it more clear. I don't know what that is.
Old Jan 22, 2004 | 03:17 PM
Cottonwoodz's Avatar
https://honda-tech.com/zerothread?id=685050
Old Jan 22, 2004 | 03:19 PM
VTECRaZeR's Avatar
Default Re: Unknown sensor on h22a (Cottonwoodz)
how much does that lil thing weight on USDM Ludes?
Old Jan 22, 2004 | 03:22 PM
4bidden's Avatar
I was told its a fuel pressure riser...not needed.
Old Jan 22, 2004 | 03:24 PM
9deuce9rr's Avatar
thanks a lot for the link to the thread cottonwoodz... i now know everything about honda engines it did help me out a great deal tho. thanks again
Old Jan 22, 2004 | 03:41 PM
jdmcivicferio's Avatar
actually its the evap purge valve, you don't need it unless you are trying to pass emissions.
Old Jan 22, 2004 | 03:52 PM
Default Re: Unknown sensor on h22a (jdmcivicferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio &raquo;</TD></TR><TR><TD CLASS="quote">actually its the evap purge valve, you don't need it unless you are trying to pass emissions.</TD></TR></TABLE>
Are you 100% sure on that?
Old Jan 22, 2004 | 03:54 PM
VTECRaZeR's Avatar
Bull....I passed Emission with my CAI without it..hehe
Old Jan 22, 2004 | 04:04 PM
fastwanabe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio &raquo;</TD></TR><TR><TD CLASS="quote">actually its the evap purge valve, you don't need it unless you are trying to pass emissions.</TD></TR></TABLE>I second that. it is the purge valve.
Old Jan 22, 2004 | 04:08 PM
So if its the purge valve, and you dont hook it up, you will have problems with the Evap system?
Old Jan 22, 2004 | 05:28 PM
Eddiebx's Avatar
its is used by the jdm ecus to modify the vaccum going to the fpr, you don't need it, just go ahead and remove it and run the vac line from the fpr straight to the manifold nipple.
Old Jan 22, 2004 | 05:31 PM
We got like 10 different answers on this now..
Old Jan 22, 2004 | 09:16 PM
9deuce9rr's Avatar
Default Re: (Cottonwoodz)
jeez... a million answers to what it is, but they all lead to the same good news--&gt; NOT NEEDED... so i'm good.
Old Jan 23, 2004 | 09:15 AM
tuan...'s Avatar
it is the evap purge valve, it isnt connected on my friends swap, no big deal
Old Jan 23, 2004 | 07:26 PM
Qfactor's Avatar
That black solenoid is the fuel pressure riser where in cold starts it blocks vacuum to the fuel press. regulator thus rising pressure and richens up the mixture for quicker warm ups and to get the system on closed loop quicker. same principle on cold start injectors used as is some late 80's and 90's early toyotas. this is not part of any Federal or California emission feature. the 49 state and California preludes use a fast idle valve which is located also in the intake manifold close to the IAC valve and a vacuum hose runs to the intake pipe near the throttle body on the other hand the JDM engines have this blocked off whit a plate. You can hook it up if you know the pin number of the ecu side, or just take if off and ignore it, but if you're trying to get your engine BAR approved(Ca, peeps) I would take it off and apply the related components that are required for the inspection. and no this not a purge solenoid and second. butterflys solenoid as this solenoids are located in totally different locations.
Old Jan 23, 2004 | 11:34 PM
Default Re: Unknown sensor on h22a (Qfactor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Qfactor &raquo;</TD></TR><TR><TD CLASS="quote">That black solenoid is the fuel pressure riser where in cold starts it blocks vacuum to the fuel press. regulator thus rising pressure and richens up the mixture for quicker warm ups and to get the system on closed loop quicker. same principle on cold start injectors used as is some late 80's and 90's early toyotas. this is not part of any Federal or California emission feature. the 49 state and California preludes use a fast idle valve which is located also in the intake manifold close to the IAC valve and a vacuum hose runs to the intake pipe near the throttle body on the other hand the JDM engines have this blocked off whit a plate. You can hook it up if you know the pin number of the ecu side, or just take if off and ignore it, but if you're trying to get your engine BAR approved(Ca, peeps) I would take it off and apply the related components that are required for the inspection. and no this not a purge solenoid and second. butterflys solenoid as this solenoids are located in totally different locations. </TD></TR></TABLE>
Thats it, Im sold..............
Old Jan 23, 2004 | 11:39 PM
4bidden's Avatar
I win...I got it first!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden &raquo;</TD></TR><TR><TD CLASS="quote">I was told its a fuel pressure riser...not needed.</TD></TR></TABLE>
Old Jan 23, 2004 | 11:42 PM
Default Re: Unknown sensor on h22a (4bidden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden &raquo;</TD></TR><TR><TD CLASS="quote">I win...I got it first!
Im going to have to call bullSHI!T on that,,,No wait......DAMN it
Old Jan 23, 2004 | 11:48 PM
Actually now that I think about it... I think you were the one, that told me it was for more fuel on cold starts..
Old Jan 24, 2004 | 08:06 PM
Qfactor's Avatar
didn't you have 1st. gen. integra with the H22, this was way back late 90's on the hybrid board. if you are do you still that ride..
