distributor question
Old Jan 19, 2004 | 09:10 PM
tonezilla's Avatar
Default distributor question
am i supposed to use an accord or prelude distributor on the h23a swap into an 94 accord ?! i got an f22 and h22 dizzy butt not an h23 . i am using an accord lx obd1 harness . thanks for any replies .
Modified by redxalien at 9:06 PM 1/24/2004
Old Jan 19, 2004 | 11:08 PM
VTECRaZeR's Avatar
Default Re: distributor question (redxalien)
I would say a prelude one since it's a prelude engine...!?!
Old Jan 20, 2004 | 11:19 AM
Sephro's Avatar
Default Re: distributor question (VTECRaZeR)
yeah use the H23A1 distributor.. They go with the engine not the car body.
Old Jan 20, 2004 | 10:50 PM
tonezilla's Avatar
darn i was afraid of that . well i dont have an h23 distributor . butt i have an h22 and a f22 distributor . is it possible i can use either one of those on my h23 ?! if it is not possible how much would a new h23 distributor go for ?!
Old Jan 21, 2004 | 05:18 AM
Sephro's Avatar
Default Re: (redxalien)
I'm almost positive that the H22 and the f distributor will not work.. I got my distributor off a guy on e-bay. It's all they sell and give you full warranty for a year... I believe it was close to $150 which is much cheaper than Honda wants.
Old Jan 21, 2004 | 07:58 AM
DW's Avatar
DW
Default Re: (Sephro)
is the h22 one internal or external coil? if its external it will work. if its internal then you can make it work but theres some wiring to it.
hope this helps
David
Old Jan 21, 2004 | 08:59 AM
thehondaguru's Avatar
The f22 should work right?
Old Jan 21, 2004 | 11:10 AM
Sephro's Avatar
Default Re: (95 lude)
actually it looks like the H22A1 - H23A1 and the F22__ I don't remember what the rest of the F22 is.. But the 92-96
they all look to be the same part number... I would call a dealorship and just ask them to confirm..
Old Jan 24, 2004 | 12:08 PM
tonezilla's Avatar
after searching for awhile . i found out that the f22 dizzy is an external coil and the h22 is an internal coil . butt what is the h23 ?! i also found out i can make a conversion from external to internal . butt still trying to find out if i can use the f22 or h22 dizzy on the h23 .
Old Jan 24, 2004 | 12:13 PM
SKDRCR's Avatar
h23 is external
Old Jan 24, 2004 | 02:41 PM
DW's Avatar
DW
Default Re: (SKDRCR)
you CANNOT use the f22 distributor.
you CAN use the h22 distributor.....btw not all h22 distributors are internal coils just the jdm ones
David
Old Jan 24, 2004 | 03:01 PM
LudeyKrus's Avatar
I'm not sure about the F22 dizzy, it may work.
The JDM H22 is internal coil, and the USDM H23 and H22 dizzy are external coil. The USDM H22 and H23 dizzy are interchangeable, so if you have a spare US H22 dizzy, use it; it will work.
If you're worried, I have a spare H23 and H22 dizzy I will sell for cheap.
Old Jan 24, 2004 | 04:24 PM
DW's Avatar
DW
Default Re: (LudeyKrus)
wow....this is the last time i'm goin to say this. the f22 distributor will NOT work part #30100-P12-A01. the h23 and h22 distributors are the same so they are interchangeable part #30105-P14-A01
David
DarkBB4
May 25, 2007 05:11 PM
Zer0skll
Dec 21, 2006 11:53 AM
Entaka
Sep 27, 2006 12:40 AM
tonezilla
Jan 31, 2004 12:16 PM
dflipmode
Jan 18, 2003 11:42 PM
