Engine seems to bog down......
Old Jan 15, 2004 | 03:58 PM
turbolude92's Avatar
Default Engine seems to bog down......
Alright guys, whenever i gas it and the boost kicks in the engine seems to bog and it holds the car back and doesnt accelerate very well. It does almost everytime i kick it and it is bugging me! I have stock injectors, walbro intank pump, aem high volume rail, aem FPR, and an safc untuned. Would this fuel setup cause this? i have 450cc dsm injectors but i was gonna wait till the day of tuning to put these in because wouldnt it mess up the air fuel ratio? or do i need more fuel and this would solve it? thanks alot for any help!
Old Jan 15, 2004 | 04:13 PM
PrecisionH23a's Avatar
Default Re: Engine seems to bog down...... (turbolude92)
Because you are not running an FMU. If you want to run the s-afc hack have it tuned and properly hooked up. Keep boosting and you're going to blow your motor.
Old Jan 15, 2004 | 04:31 PM
Default Re: Engine seems to bog down...... (GudeH23a)
i was running the vortech fmu and it still did it when i had that on.
Old Jan 15, 2004 | 05:42 PM
H23vtecEG's Avatar
check for wear on cap and rotor. replace wires and plugs. sounds like car isnt gettign spark.
Old Jan 15, 2004 | 05:49 PM
i will check these....thanks
Old Jan 15, 2004 | 05:55 PM
cstay's Avatar
Default Re: (turbolude92)
sounds more like a fuel problem because if he wasn't getting spark when he opened it up it would probably feel more like a skip or a rough running motor altho i was running 1 cylinder short and it felt just dead. Make sure the spark plug isint sparking into the block and not getting spark in the chamber.
Old Jan 15, 2004 | 06:13 PM
Default Re: (cstay)
alright i will check that too. thanks
NOSED_CRX_VTEC
May 18, 2003 05:59 PM
T3T495GSR
Apr 3, 2003 08:53 PM
pelotudo
Sep 14, 2002 12:35 PM
bronzehatch
Jul 22, 2002 02:27 PM
ludelvr
Jun 4, 2002 10:38 PM
