header question
Old Jan 16, 2004 | 06:01 AM
Timmy Joe's Avatar
Default header question
I did search for this info and I did find one thread that was close
https://honda-tech.com/zerothread?id=174687 but it was for the differences stock header on an 5th gen sh vs dc header and there were no real noticeable gains in performance and hp. I have a 98 lude type s Stock exhaust. I noticed it has a factory header. So is it worth to replace factory with after market on the type s lude? I don't want to waste money if all its really going to do is look cool. Is there a significant gains in hp and torque (significant = 5-7 hp gain)
Old Jan 16, 2004 | 06:07 AM
Asian Persuasion's Avatar
it IS worth it to replace the factory header... just not with the DC. If you want some good performance you can easily get a significant amount of power from a Mugen or SMSP header. But expect to pay more.
Old Jan 16, 2004 | 06:09 AM
ludefreek's Avatar
so you have a factory type-s 5th gen? did you have it imported from Japan or do you mean you have a 5th gen base (non SH)?
Old Jan 16, 2004 | 06:53 AM
Timmy Joe's Avatar
Default Re: (ludefreek)
Factory 5th gen base non SH
Old Jan 16, 2004 | 10:32 AM
ludefreek's Avatar
Default Re: (Timmy Joe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmy Joe &raquo;</TD></TR><TR><TD CLASS="quote">Factory 5th gen base non SH</TD></TR></TABLE>
ok, just wondering cause the 5th gen type-s is strictly JDM as far as i know. but as far as getting a header, i would go with a mugen or SMSP. i think there is another called ANR that someone here talked about that was comparable to the SMSP and a little cheaper.
Old Jan 16, 2004 | 11:05 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludefreek &raquo;</TD></TR><TR><TD CLASS="quote">
i think there is another called ANR that someone here talked about that was comparable to the SMSP and a little cheaper.</TD></TR></TABLE>
the an-r will have clearence issues on the lude,
i believe prospeed makes a pretty good one for it
Old Jan 17, 2004 | 01:47 PM
ludeboy555's Avatar
Default Re: (SKDRCR)
where can u get prospeed headers.
Old Jan 17, 2004 | 05:15 PM
SKDRCR's Avatar
Default Re: (ludeboy555)
my bad, you'll probably have to remove the ac and maybe a crossmember
for that one too here's the site
http://www.prospeed-performance.com
Old Jan 17, 2004 | 05:53 PM
supaZZZleepa's Avatar
i hear a lot of bad things about an-r from previous posts...i have a mugen 4-1 and its
Old Jan 18, 2004 | 03:21 PM
jji106's Avatar
Default Re: (supaZZZleepa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supaZZZleepa &raquo;</TD></TR><TR><TD CLASS="quote">i have a mugen 4-1 and its </TD></TR></TABLE>
Are you driving a Civic or Integra?
The Mugen Header for the 5th Gen is 4-2-1! If you get one, make sure you get the one for your car. The Base and SH Header are different.
I have the Mugen Header, Exhaust, Suspension, etc!! I love it!
Old Jan 18, 2004 | 07:21 PM
Default Re: (jji106)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jji106 &raquo;</TD></TR><TR><TD CLASS="quote">
i got the 4-1 mugen header for the 5th gen bb6. you can get it at kingmotorsports.com
Old Jan 19, 2004 | 10:03 AM
jji106's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supaZZZleepa &raquo;</TD></TR><TR><TD CLASS="quote">i got the 4-1 mugen header for the 5th gen bb6. you can get it at kingmotorsports.com</TD></TR></TABLE>
Really?... Why don't you go out to your car pop the hood and also try to look underneath it where your header would be.
If you look from the top, you will notice that you have 4 pipes extending from the engine block. Follow those down and underneath your car.
You will notice that they converge into 2 pipes. Now, keep following those 2 pipes and you'll notice that they converge into 1 pipe before going into your catalytic converter or test pipe!
See... you have a 4-2-1 Header! Mugen doesn't make a 4-1 header for the 5th Gen Prelude.
Why don't you call King Motorsports and ask them. I've been there and talked to them a lot, they are quite helpful!
B18 Piston
May 17, 2008 01:07 PM
Fei8Lo
Oct 10, 2007 12:57 PM
LudeyKrus
Aug 17, 2003 10:14 AM
SMSP
Jun 18, 2003 05:14 AM
96SR-V
Apr 6, 2003 09:15 AM
