what is this part???
Old Jan 21, 2004 | 02:22 PM
tuan...'s Avatar
Default what is this part???
i need help on identifyin a part of my engine. it is the housing that the drivers side axle goes into, and the its right behind the oil pan. not the transmission but the part to the left of it (if your lookin at it from the bottom). i have a hose/line that comes outta the top of it and i have no idea where it goes. the line isnt quite as small as a vacuum line and not as big as a coolant hose. i can see it on the drivers side with the wheel off. it also has wat looks like a metal insert in it. i have no digi cam or else id take pics. pleeeeeeeeease help
Old Jan 21, 2004 | 03:09 PM
PirateMcFred's Avatar
Default Re: what is this part??? (h22a4_dc2)
Does the "housing" look like this?
if so check out http://www.hondaautomotiveparts.com to see if the parts diagrams show you where this hose/line comes from/goes to.
HTH
the Pirate
Old Jan 21, 2004 | 03:25 PM
tuan...'s Avatar
whoo hoo that is it!! wat is it called..
Old Jan 21, 2004 | 03:37 PM
H22A EG6's Avatar
Default Re: what is this part??? (PirateMcFred)
wtf is that
Default Re: (h22a4_dc2)
ATTS automatic torque transfer system. it is just an expensive heavy limited slip differential
Old Jan 21, 2004 | 03:54 PM
tuan...'s Avatar
great now im screwed with 40lbs of dead weight wen i get my obd1 ecu...
H22A EG6's Avatar
Default Re: (PirateMcFred)
oh good info thx
Old Jan 21, 2004 | 04:07 PM
Welllll. If you really want to remove that 40lbs I have a spare H23 tranny (see sig) and intermediate shaft ($50) and for $50 I can mill you an adapter plate that will let you mount the intermediate shaft to your ATTS block. So for $350 + shipping you can have a regular trannied fifth gen.
I have all of the measurements for the bracket since I bought a type-s block. That goes for anyone else interested too.
the Pirate.
Old Jan 21, 2004 | 05:40 PM
tuan...'s Avatar
well spending $350 for 40 lbs less isnt really reasonable. im not too worried about, its jus 40 lbs dead weight...i think it was satan_srv that said he doubted that i had atts... well guess wat i do lol. greatttttttttttttt
Old Jan 21, 2004 | 05:50 PM
biglew's Avatar
ATTS is not a LSD.
Mr_ET
May 15, 2007 02:23 PM
D15Bbigred
Mar 1, 2007 07:36 PM
blue_hatch
Feb 13, 2007 06:57 PM
Xerxes
Jan 27, 2002 10:48 PM
