No start
Old Jun 1, 2020 | 05:36 PM
Matthew Beheler's Avatar
Default No start
The green key light only comes on after I try and start the car and cut the switch off. I have power the the battery 13.5 amps. But still no starter engagement. I need some help with the diagnosis. The only way to get it running is to bump start it.
Old Jul 29, 2020 | 09:40 PM
Lucifersure777's Avatar
Default Re: No start
Is the green key light flashing?
Battery terminals tight and clean?
Fuses good?
Good ground to engine and power to starter?
Good signal wire to starter?
I sure hope your battery isn't producing 13.5 amps. Thats nowhere near enough for your starter. I'm sure you meant volts
When you say bump start do you mean roll start? Roll it and dump the clutch in gear key on? Or do you mean crank it with jumper cables hooked up?
soto2635
Jan 15, 2009 10:44 AM
lPat
Nov 3, 2007 08:19 AM
jorge59la
Sep 16, 2007 06:28 PM
DVS Luder
Nov 24, 2004 12:41 PM
lowblazin
Nov 25, 2003 10:00 AM
