Code P0301
Old Apr 9, 2020 | 12:55 PM
SimplyRude's Avatar
Icon4 Code P0301
Check engine light is on and also ATTS light is on my 1997 Honda Prelude
Last edited by SimplyRude; Apr 9, 2020 at 12:57 PM. Reason: forgot to add year make and model of car
Old Apr 22, 2020 | 01:54 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Code P0301
P0301 is misfire on cylinder #1.
Verify ignition components are in good condition.
Verify no oil down the spark plug tube.
Verify spark plug is not loose, worn, damaged, or incorrectly gapped.
Verify valves are correctly adjusted.
Verify EGR ports in runners are clean. If you have over 80K miles and the original cast plugs are still installed in the intake manifold runners then they are most likely getting plugged up.
You will need a slide hammer and replacement plugs 17199-PT3-AHM,
Link on how to clear H22 ports https://www.preludepower.com/threads...w-pics.275440/
Link oh how to clean F22 ports on a 90-93 Accord https://www.hondaaccordforum.com/for...ned-t2t013.pdf
ATTS light will come on if it is disabled or in limp mode. Since no codes from the ATTS were stored, most likely it is on due to the engine code and the light will most likely clear after P0301 was been repaired.
Old Apr 22, 2020 | 06:13 AM
SimplyRude's Avatar
Thanx so much for all your help
Spoon DelSol
Feb 27, 2005 09:19 AM
importdude2000
Jul 17, 2004 12:53 PM
SigSeriesB18
Aug 22, 2002 09:02 PM
