H22a Flywheel & Clutch replacement
I picked up an H22a swapped 1999 SH Prelude awhile back and she needs a clutch replacement (slipping clutch). I was wondering if H22a4 clutch kit and flywheel will fit up to the H22a? From what I am finding on the internet and from what the previous owner said is that it should, but just wanted to double check on here. Also, does anybody have any recommendations as to what kits/flywheel I should get? I am looking at getting a lighter flywheel and potentially a stage 2 sprung clutch. Any input would be greatly appreciated!
Re: H22a Flywheel & Clutch replacement
All H22 uses the same clutch, so no worries there.
Unless you are making some decent power, oem clutch is good, I ran an Exedy oem replacement clutch for many years, up to and including 100s of drag passes making 300+ whp on slicks.
@snobordboy Any recommendations on a flywheel? This is the Exedy I was looking at. (EXEDY FWHDA01)
https://www.rockauto.com/en/moreinfo...55677&jsn=2170
