fire problem 2k lude
Old Jun 18, 2005 | 07:52 PM
franklude's Avatar
Default fire problem 2k lude
I just got my 2k turbo prelude and it is actually runin on 2 cylinders.....
I made under 200KMS with this setup and I didn't boost more than 4pounds
The cylinders 1,2 (start from the left of the engine bay) don't mind if I retire the spark plug while the car is idling.
the cylinders 3-4 are running normally
do you think my motor is breaking away?
Old Jun 18, 2005 | 08:30 PM
PrettyLude's Avatar
compression and leakdown test time
Old Jun 18, 2005 | 09:04 PM
94Vtecluder's Avatar
Default Re: (PrettyLude)
What else do you need a rod through your block to tell you it's breaking down?
Old Jun 18, 2005 | 09:56 PM
mgags7's Avatar
Default Re: (94Vtecluder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder &raquo;</TD></TR><TR><TD CLASS="quote">What else do you need a rod through your block to tell you it's breaking down?</TD></TR></TABLE>
sounds like you need some *****..... chill out....
Old Jun 19, 2005 | 07:13 AM
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
sounds like you need some *****..... chill out....</TD></TR></TABLE>
What are you babbling about child. He asked a simple question, and I gave an even simpler answer. If that doesn't suit you then go troll elsewhere.
Antilag
Feb 12, 2006 04:03 AM
h22a193
May 11, 2005 04:44 AM
Conechaser
May 25, 2003 06:36 PM
