Vtec not working ?
Old Jun 13, 2005 | 10:36 AM
abolish415's Avatar
Default Vtec not working ?
is there any way to check the vtec ?? any suggestions ?
Old Jun 13, 2005 | 10:48 AM
2lude4u's Avatar
Default Re: Vtec not working ? (abolish415)
Are you asking because you think your vtec isn't working and you want to know how to determine if it is functioning or not? Or are you asking how to determine why it's not working? Are you throwing any codes?
In either case this is a good thread https://honda-tech.com/zerothread?id=830163
Monkey Fing a Coconut's Avatar
There are a lot of things to check, oil pressure, ecu, wiring, oil pressure switch, vtec control solenoid, but first thing i would check is if there is any slight little dent in the oil pan, it will block oil flow and reduce oil pressure below the required 55psi to engage vtec, and look closely, even a slight dent in the right spot will block the flow enough
94wip
12
Jun 20, 2024 07:23 PM
tigasin
Nov 14, 2008 11:58 PM
jordan_rael_420
Sep 17, 2008 04:07 PM
H22T94
Jul 25, 2004 12:50 AM
Cm91h22a
Sep 9, 2003 06:59 PM
