electrical issue
Old Jun 19, 2005 | 10:12 AM
john d
Guest
Posts: n/a
Default electrical issue
lately, everytime i attempt to start the car it would turn on but act like its about to die, lights from my boost gauge, oil pressure gauge, and cluster would be on but very dim. everytime i would rev it they would become brighter!? this only happens every once and a while.
what could it be?
-bad ground?
-bad battery?
-dirty battery terminals?
-main relay?
-bad alternator?
-bad starter?
im not home right now so cant really check just seeing what you guys think it is
Old Jun 19, 2005 | 11:11 AM
lunarcry's Avatar
Default Re: electrical issue (john d)
I had something like that happen to me a day before my battery die.
i do not think it would be the starter but you other choices above are worth checking
Old Jun 19, 2005 | 03:40 PM
PrettyLude's Avatar
check the battery voltage with a multimeter, when your car is on, the voltmeter should read 14 volts
Old Jun 20, 2005 | 09:30 PM
john d
Guest
Posts: n/a
Default Re: (PrettyLude)
Old Jun 23, 2005 | 01:37 AM
john d
Guest
Posts: n/a
Default Re: (john d)
battery is good
Old Jun 23, 2005 | 06:07 AM
Shakes's Avatar
space cadet
alternator.
how close is your wastegate to it? the heat from that has cause many to go bad.
Old Jun 23, 2005 | 10:04 AM
prelittlelude's Avatar
Default Re: (Shakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes &raquo;</TD></TR><TR><TD CLASS="quote">alternator.
how close is your wastegate to it? the heat from that has cause many to go bad.</TD></TR></TABLE>
yeah i second this motion, the ELD and alternator talk to each other to control how much output the alt has, excesive heat from your turbo mani or wastegate can do this.
Old Jun 23, 2005 | 10:43 PM
john d
Guest
Posts: n/a
Default Re: (prelittlelude)
never through/heard of that, but i dont see it being a problem b/c of of the mani and wg arent to close to the alt.
Integ808
Oct 16, 2008 02:57 AM
Si_eg6
Jul 14, 2008 02:47 PM
CiViC I2aCeI2
Jan 5, 2006 01:01 PM
twenty
Jun 19, 2005 11:11 AM
