problem: running really rich?
what would cause my 95 lude to run really rich... at idle, it studders and the exhaust sounds like crap.. i can even see black smoke coming out sometimes..
I just replaced the o2 sensor with a new oem one, and there r no cels... The car idles kinda lousy, and acros the low rpms it bogs and hesitates...
what thins could it be?
ill try some injector cleaner
that is what i think it is now.. something with the injectors
if i pull them off, is there naything i can do?
Does it burn oil?
Burnt oil will trick your o2 sensor into thinking the car is lean, causing it to add more fuel to compensate. Often the check engine light wont come on until the o2 sensor has quit working because of the burnt oil deposited on it.
-Shawn
-Shawn
car runs and bogs like **** when first started.. after its warmed up it doesnt bog that much.. but runs mad rich and gas milege sucks
You need to look for a vaccum leak. Any air leaked into the intake dilutes what the O2 sensor sees and since the mixture appears to be lean it increases the pulse width to the fuel injectors. That being said, despite your replacement of ignition parts recently with quality parts, have you actually verified that you are getting spark at all cylinders all the time? Hook up a timing light to each wire and watch for misses.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod »</TD></TR><TR><TD CLASS="quote">fuel pressure? what ECU are you using?
not sureo n fuel pressure.. stock p13 ecu
vafc
Right now its at a shop for diagnoses..
main questin as of now...
IS a 99 sohc non vtec o2 sensor = 95 prelude vtec o2 sensor?
both are 4 wire!?
vafc
both are 4 wire!?
i have 133k and it was done at 90
now i have another HUGE problem
its overheating like crazy
it never even settles down... it just increaes pretty quickly.. after 10 minutes it was around 235 so i shut down, and rewired my slim fan (i have a c+r racing radiator) so that is always on.. and it didn't help
IM NOT leaking coolant
waterpump?
waterpump?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 »</TD></TR><TR><TD CLASS="quote">waterpump?</TD></TR></TABLE>
A good possibility, ru leaking anywhere from the head? Hopefully it isn't a headgasket.
ummm, ive had this same problem.. the overheating may be due to your coolant system neding bleeding.... which also has an afftect on how it runs.. i had air in my system and the car ran OK but overheated when i was stopped for prolonged period of time. .. ran pretty rich and boged.. i tried everything , fuel filter.. timing... o2 sensor....vacc lines... intake gaskets... injector cleaner... cap, rotor, plugs, wires,... check your idle adjustment screw make sure its not backed out to far... and bleed the coolant...... mine still hesitates a little.. and i am still confused... i have come to a faulty knock sensor as my conclusion... i duno about your.. but on my.. it doesnt feel like its "bogging" it feels like its having timing pulled... which is due to knock sensor being faulty.. i have aquired a new one and am about to put it on ill let ya know how it goes
Yeah - unfortunately, i have the same problem; however, I had a termporary solution - use the p14 ecu. And it runs great....a tad bit rich though......
Before you say anything - i'm getting it out the shop right now(body shop that is - so i havne't been driving it EVERYWHERE) - it still runs great......
I'm going to change my o2, IAT, and map........I threw a code once, it was either a code 1 or 10 - thats the o2 or iat.............
I get things pretty cheap by the way, so if anyone needs anything just let me know. I'm going to change these sensors probably here in the next week or so and get back to you.
I can get a brand new map for $207 and an IAT for $38.............o2 for $82
Oh i forgot - i hooked up my vafcII to the p13 ecu (remember it drives like **** - hardly driveable).........I adjusted the fuel and everything and I got it to a driveable state - so I drove around in it, abusing it trying to throw a code, and it finally did - (1 or 10)........
Sometimes it even went into limp mode, but i still don't know which code it was........
