trans fluid?
Old Aug 27, 2005 | 03:15 PM
Jordans95si's Avatar
Default trans fluid?
how often should i change trans fluid and is this difficult to do?
Old Aug 27, 2005 | 03:31 PM
specbb6's Avatar
Default Re: trans fluid? (Jordans95si)
its very simple, not sure about the time though. You can check the fluid level if you have never change it before.
specbb6's Avatar
Default Re: trans fluid? (specbb6)
btw, your car is MT or AT?
Old Aug 27, 2005 | 03:48 PM
MT, and where do i check it at, sorry i've only been into this car junk for about a year or so
Old Aug 27, 2005 | 05:55 PM
BB6racer's Avatar
ok i'm not sure how to post a pic or a link, but go to hondaautomotiveparts.com and make your way to a Prelude 97 Base Model MT housing. you drain the tranny with bolt #12, and fill it with bolt #15. it helps if you take off your intake, and passenger side wheel, and if you have a funnel and vinyl hose. you fill up the tranny until fluid overflows from the upper bolt hole.
Clash0901
Nov 4, 2009 05:43 PM
2lobes1engine
26
Jun 29, 2004 08:27 PM
Too_Funny
Nov 8, 2002 03:34 PM
