bleeder screw?
Old Aug 28, 2005 | 03:34 PM
preludeshdriver's Avatar
Default bleeder screw?
I wwent to switch my fans out and took off the upper radiator hose. I now want to re-fill the radiator although I want to make sure there is not air in the lines, radiator. How do I bleed the system on my 97 prelude? Where is the bleeder screw?
the manual i have has no diagram.\ thanks
Old Aug 28, 2005 | 04:43 PM
flip1199's Avatar
Default Re: bleeder screw? (preludeshdriver)
i'm not sure if the h22 is the same as the h23 but if it is just follow the lower radiator hose to where it meets the engine and there should be the bleeder valves right on top.
Old Aug 28, 2005 | 05:31 PM
Default Re: bleeder screw? (flip1199)
Great, thanks for the info, I was under the impression that it was on the thermostat housing attached to the upper hose, but all I found was two mounting screws.
Old Aug 28, 2005 | 05:35 PM
shinlegion's Avatar
Different set up wth h22 and h23, then?
mike4g
Jul 13, 2008 01:55 PM
blueH23prelude
Sep 24, 2007 09:52 PM
black_bb1
Feb 13, 2006 06:11 AM
pnltnc
Mar 30, 2004 06:30 PM
DropSquadCivic
Aug 14, 2003 07:16 AM
