Error code 17(Vehicle Speed Sensor)
Old Aug 28, 2005 | 07:27 AM
jam05pr's Avatar
Default Error code 17(Vehicle Speed Sensor)
I'm throwing error code 17 which is the VSS. Now I am just wondering were this sensor is. Can somebody please tell me where this dang sensor is. Thanks.
Old Aug 28, 2005 | 07:43 AM
rawNArsxS's Avatar
Default Re: Error code 17(Vehicle Speed Sensor) (jam05pr)
i have the same problem. ever since i did my swap my speedo hasnt worked. threw the same code, havnt worried about locating the sensor yet though im too busy crying over buyin a $300 sensor
Old Aug 28, 2005 | 07:55 AM
Rad Racing's Avatar
Bart Taylor Look-alike
Someone might have a photo to show, but I will give you a brief explanation. Take the intake piping for better access and look towards the back of the tranny to the left and under the throttle body (it's sits on top). A 10mm bolt holds it in. Are your speed sensors bad or not plugged in? If they are bad look at a wrecking yard, especially if it's a honda wrecking yard or find someone with a toasted tranny and buy it. If neither of you find one by tuesday PM I might have one at my buddies shop on an old tranny.
Old Aug 28, 2005 | 07:58 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jam05pr &raquo;</TD></TR><TR><TD CLASS="quote">I'm throwing error code 17 which is the VSS. Now I am just wondering were this sensor is. Can somebody please tell me where this dang sensor is. Thanks.</TD></TR></TABLE>
It's on the far right in this pic with the short black hose coming off of it--
Old Aug 28, 2005 | 11:10 AM
Ideal's Avatar
i dont have the link but look up axle install and the topic creator shows how to fill your tranny fluid via the vss...
Old Aug 28, 2005 | 12:13 PM
Chiovnidca's Avatar
Default Re: Error code 17(Vehicle Speed Sensor) (93boostedLUDE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93boostedLUDE &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem. ever since i did my swap my speedo hasnt worked. threw the same code, havn't worried about locating the sensor yet though im too busy crying over buyin a $300 sensor </TD></TR></TABLE>
How do you know the sensor is bad if you haven't checked. It could just be unplugged?
Old Aug 28, 2005 | 01:48 PM
rawNArsxS's Avatar
Default Re: Error code 17(Vehicle Speed Sensor) (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
How do you know the sensor is bad if you haven't checked. It could just be unplugged?</TD></TR></TABLE>
brother in law checked it when he was fixin my tranny. i just said i dont know where it is, i never said anythin about not tryin to have it fixed
Old Aug 28, 2005 | 04:30 PM
jam05pr's Avatar
well now I know where it is. Thanks guys. Does the sensor have to be from a h22 or can I use another honda motor's vss?
Old Aug 29, 2005 | 01:59 PM
rawNArsxS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jam05pr &raquo;</TD></TR><TR><TD CLASS="quote">well now I know where it is. Thanks guys. Does the sensor have to be from a h22 or can I use another honda motor's vss?</TD></TR></TABLE>
good question. im runnin an h22 with a 23 tranny...do i have to use a 23 part or can i use the one from my old 22 tranny?
Old Aug 31, 2005 | 02:15 PM
rawNArsxS's Avatar
bump...any1?
Old Aug 31, 2005 | 04:21 PM
Dameltajo's Avatar
Old Aug 31, 2005 | 07:59 PM
kulrevon's Avatar
Default Re: Error code 17(Vehicle Speed Sensor) (Dameltajo)
I am almost positive the only difference is sometimes the powersteering hoses. I dont believe the f22 tranny vss have it but i could be wrong.
leonardsmith
Honda CR-V & Element
Dec 1, 2021 06:33 PM
kslimm0714
Apr 18, 2006 04:11 PM
roydogg
Aug 9, 2004 01:41 PM
justing
Nov 4, 2003 02:40 PM
guyuenvy
Apr 30, 2002 09:59 AM
