Compression question
Old Aug 25, 2005 | 11:49 AM
quadiv20's Avatar
Default Compression question
Im going to be building an H22a4 for my 98 Base, Its gonna be my daily driver, so I don't need huge HP 230-250 at the crank will be fine. Im going Crower or Eagle con rods, ARP head studs, PnP head w/ skunk2 Valve train, and maybe a 30-50 shot of N2O. My question is what compression and Piston should I go with?
I would prefer not to sleeve the block, but will if need be.
Thanks
-B
Old Aug 25, 2005 | 12:02 PM
2lude4u's Avatar
Default Re: Compression question (quadiv20)
If you're going to sleeve the block bump it up to 11:1 or 11.5:1 (easily streetable), if you leave the stock pistons in there you can throw in some flat valves and a thinner headgasket to bump it up.
I don't have any experience with nitrous, so I don't know if it's best to sleeve or leave the stock pistons in there. However, based on my experience boosting stock vs. built blocks I would suggest sleeving it.
You can get 230-250 crank HP on a stock block without having to use NO2. I'm currently close to '230 crank HP' on a stock JDM block that has bad rings & flat valves in the Head, once I get a fresh block in there (debating built or stock) I should be closer to 250 crank HP (215-220 whp).
Shadowcat
Mar 5, 2014 09:47 AM
gunsmoke
Sep 6, 2009 01:30 PM
civicjoe
Apr 7, 2008 11:04 AM
WRX 32
Sep 21, 2007 09:45 PM
slownlow90
Mar 21, 2005 10:12 AM
