H22 time?
Old Oct 7, 2005 | 07:23 AM
Mad Hatter's Avatar
Default H22 time?
so about two weeks ago i bought a '92 prelude si off ebay, after i got in a wreck with my accord, and last week i brought it in to be inspected. the only problems i've had with it was that it occasionally had trouble starting up and the CEL would turn on for the EGR valve after driving a while. after the people at honda looked at it they told me that i pretty much need a new engine (the compression was really low and would be cheaper than troubleshooting). i'm not really a mechanic, but it looks like i've pretty much got 4 choices:
swap it out with an H22
replace it with another H23
replace it with the f22 from my accord
or try to fix the engine i have.
If anyone can help me out with this decision, i'd REALLY appreciate it
Old Oct 7, 2005 | 07:27 AM
iLude's Avatar
Default Re: H22 time? (cdn92si)
Two suggestions:
JDM H22
or
F22 + Boost
Old Oct 7, 2005 | 07:33 AM
PrettyLude's Avatar
what's ur spending limit?
Old Oct 7, 2005 | 09:06 AM
Mad Hatter's Avatar
Default Re: (PrettyLude)
i'd like to keep it under 4K if i can...i'd prefer to go as cheap as possible, but if an h22's worth the extra money, i was thinkin that would be the way to go. at hmotorsonline, the price diff doesnt look that bad, and i need a new clutch neway...thanks for your input
Old Oct 7, 2005 | 10:38 AM
4LugR's Avatar
Default Re: (cdn92si)
H22 get the optional LSD if you can..
Old Oct 7, 2005 | 01:14 PM
Don Jefe's Avatar
Default Re: (AEMPrelude916)
Well, it depends on what you want also...
I, for one, would boost your f22. You already have a motor that can tolerate boost well, then you can spend your money on a killer boost setup. However, if all out reliability is what you want, then i would suggest the h22 w/ LSD.
Power or reliability, those are my .02.
Old Oct 7, 2005 | 01:24 PM
LudemanDan's Avatar
You will save about $300/yr on gas with an F22 over an H22. You can figure out a more exact estimate on http://www.fueleconomy.gov.
Old Oct 7, 2005 | 05:41 PM
Mad Hatter's Avatar
Default Re: (LudemanDan)
since i'm really need something reliable i think im just gunna stick with the h22...i've found a place that'll put one in (usdm, i believe) with a new clutch for around 2500 and i'll just keep my h23 trans....thanks everyone for your help
Old Oct 7, 2005 | 06:59 PM
95whiteludesi's Avatar
I would boost the H23 or F22; or you could do a F22 block w/ h23 head N/A setup with H22 cams. That would have more torque than the h22.
upgrayedd
Apr 15, 2011 09:35 PM
piropal
Nov 7, 2007 09:27 AM
embajada
Aug 21, 2007 03:45 AM
thing
Feb 9, 2006 06:04 PM
accordsi23
Mar 16, 2004 01:30 PM
