compression question asap
Old Feb 9, 2006 | 05:45 PM
coreyfrenzel's Avatar
Default compression question asap
ok i did a compression test and from the front of the motor (t belt) 185,o,185,185psi. what would cause this and what could it be? need valve ajusted? or bent valve? thank you
Old Feb 9, 2006 | 06:43 PM
The Weather Man's Avatar
Could be many things.
sounds to me like a piston problem - whatever it may be. I don't think a valve that needs adjusting would cause it to be zero........hm....
Old Feb 9, 2006 | 06:47 PM
CGags13's Avatar
Default Re: compression question asap (coreyfrenzel)
do you think you did the test wrong on that cylinder?
a valve would have to be WAY out of adjustment to do that
Old Feb 9, 2006 | 07:10 PM
SteveoBA8's Avatar
Default Re: compression question asap (CGags13)
Make sure if your using a rubber hose type tester( some are just one straight metal piece ) to snug up the connections after every cyl test. Mine does that ****.
Old Feb 10, 2006 | 05:23 AM
ThE PiMpiN Co's Avatar
Default Re: compression question asap (SteveoBA8)
Did you let go of the pressure release switch? I dont see how you could have got a 0 even if your engine was f*cked.
Old Feb 10, 2006 | 05:25 AM
Default Re: compression question asap (aRaBiAn RiCe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aRaBiAn RiCe &raquo;</TD></TR><TR><TD CLASS="quote">Did you let go of the pressure release switch? I dont see how you could have got a 0 even if your engine was f*cked.</TD></TR></TABLE>
maybe he forgot to put a piston in ?
Old Feb 10, 2006 | 05:30 AM
Default Re: compression question asap (TheKINGPin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKINGPin &raquo;</TD></TR><TR><TD CLASS="quote">
maybe he forgot to put a piston in ? </TD></TR></TABLE>
Maybe he forgot to put the compression tester in.
Old Feb 10, 2006 | 09:16 AM
brolli's Avatar
Maybe he forgot to put the compression tester in. </TD></TR></TABLE>
most likely...i mean he didnt say anything about the car running bad. obviously with 0 psi it would be running like hell.
Old Feb 10, 2006 | 09:27 AM
Default Re: compression question asap (brolli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brolli &raquo;</TD></TR><TR><TD CLASS="quote">
most likely...i mean he didnt say anything about the car running bad. obviously with 0 psi it would be running like hell.</TD></TR></TABLE>
If it ran...
Old Feb 10, 2006 | 09:29 AM
It would have ran, not that bad though. It'll be like taking a spark plug wire off........mine popped out before - it just depends on which cylinder is out.......you'll definately notice the difference though -but it would run. Ooooh, when cylinder 1 is out, it sucks ball sacks.
Old Feb 10, 2006 | 09:44 AM
Default Re: (TheKINGPin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKINGPin &raquo;</TD></TR><TR><TD CLASS="quote">It would have ran, not that bad though. It'll be like taking a spark plug wire off........mine popped out before - it just depends on which cylinder is out.......you'll definately notice the difference though -but it would run. Ooooh, when cylinder 1 is out, it sucks ball sacks.</TD></TR></TABLE>
Yeah but when you take a spark plug wire out, there would still be some compression in that combustion chamber, opposed to 0 psi compression.
It actually is starting to sound like you forgot to put a piston in somewhere.
Old Feb 10, 2006 | 11:57 AM
93_lude's Avatar
my brothers name is corey frenzel but i am the one with the lude. it runs! like ****. see the problem is i did a t-belt change and when i was done this is what i got i dont know what happend. i know the piston is there. but i dont know why i wouldnt have any compression. the 4 rockers for that cylander are loose. what could it be? thank you guys
Old Feb 10, 2006 | 12:05 PM
Rosko's Avatar
Default Re: (93_lude)
thats a bent/stuck valve. i would guess when you put the head back on and were rotating the motor to line up all your timing marks that you made some piston to valve contact somewhere and bent a valve. its best to line up the cam gears and crank close to where they need to be before you drop the head on.
Old Feb 10, 2006 | 12:47 PM
93_lude's Avatar
i never had the head off and can you bent a valve be hand rotating the crank with no belt? i might have done that but i understand you have to be really strong to do that.
DCiFound
Sep 7, 2014 10:43 PM
89civichb
11
Mar 10, 2009 08:26 AM
crxvtecturbo
Apr 18, 2005 08:51 AM
the.hamburglar
May 7, 2004 07:00 PM
platinum00
Aug 6, 2003 01:12 PM
