Need help fast..!!
Old Feb 14, 2006 | 12:50 PM
invasian_boy's Avatar
Default Need help fast..!!
i have a 99 prelude which the car bogs alot...i was wondering if you have air bubbles in your clutch lines or clutch would that cause the car to bog???
Old Feb 14, 2006 | 12:51 PM
The Weather Man's Avatar
no, but it will cause the clutch to be very soft - if not sticking to the floor.
What mods do you have done?
Whats the very last thing you've done to your car before the problem started?
AndyD's Avatar
Default Re: Need help fast..!! (invasian_boy)
No, that will NOT cause your car to bog.
What led up to the bogging?
Old Feb 14, 2006 | 02:21 PM
Default Re: (TheKINGPin)
well i swapped in a 99 h22a4 with 60ks miles on it and i put in a stage 1 clutch with a 12lb flywheel...i also bought new headers for it..also the car has intake and exhaust system on it before....and hrmm i took out the power steering..
Old Feb 14, 2006 | 10:24 PM
Default Re: (silverlude15)
i swap the motor by myself with help of friends
Old Feb 15, 2006 | 04:03 AM
championshipwhite93si's Avatar
Default Re: (invasian_boy)
could be you have your sensors hooked up backwards, or you have a vaccum leak on the manifold. does it bog all the way through the rpm band or does it rev up good after a certain point?
clean99si
May 8, 2011 10:47 AM
jcsantos90
Transmission & Drivetrain
Jan 21, 2011 06:29 AM
Tribaltwin
Jul 12, 2005 04:27 PM
gobblebox59
Oct 2, 2004 03:44 PM
aslude
Jul 18, 2004 12:52 PM
