Problem with power locks
Old Feb 8, 2006 | 04:13 PM
Mik3's Avatar
Default Problem with power locks
Ok, heres the situation- I go to use the keyless entry to unlock the door and it unlocks. When I go to lock the door shortly after (a few seconds) with the keyless, it won't lock. Even if I try to lock or unlock the doors with the switch on the door, it won't work after about the second time (car not running). I changed the battery in the keyless and it did the same thing. I got a new car battery a few days ago and it still does the same thing.
It sounds like the door locks want to work but it just doesn't have enough power...What could it be?
Old Feb 8, 2006 | 07:34 PM
Mik3's Avatar
Default Re: Problem with power locks (Mik3)
BUMP Nobody knows whats wrong with my door locks?
Old Feb 8, 2006 | 08:36 PM
The Weather Man's Avatar
Hm, since no one is helping you - i'll try.
well lets see.............if the lockign system uses a relay - thats a definate possibility - relays go in and out all the time, once they're starting to go bad.
Otherwise, i wouldn't know.............
Old Feb 8, 2006 | 09:12 PM
Mik3's Avatar
Default Re: (TheKINGPin)
I don't know much about electrical components but how do i check the power lock relays?
Old Feb 8, 2006 | 10:08 PM
Jos3ph's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mik3 &raquo;</TD></TR><TR><TD CLASS="quote">It sounds like the door locks want to work but it just doesn't have enough power...What could it be?</TD></TR></TABLE>
it might be an obstructed door lock linkage or a problem with the door lock actuator. PM if you want a write-up to check.
lrhtech
Jul 13, 2015 05:30 PM
deerman2701
Jun 14, 2011 05:58 PM
snoozie978
May 28, 2008 07:09 PM
danb18c
Jan 20, 2008 05:49 AM
Calavera
Jun 13, 2003 02:56 PM
