another clutch problem
Old Feb 12, 2006 | 12:15 PM
BALLIN H22 EK's Avatar
Default another clutch problem
okay ive searched about clutches going out but some of the symptoms arent the same and some are. so i just wanna hear what some of u say/ think it would be.
to start off i have a exedy stage 1 clutch and a jun lightened flywheel with about 40K on them.
well i was launghing from first gear and then i went to shift to second and it wouldnt go in. i had to force it in with all my strength. and now i have to like force it into all the gear pretty much. also when im at a stop i can let the clutch out then put the clutch back in and the car is still rolling like the clutch is out. i replaced the slave cylender and it still does the same ****. is the clutch going out or what. any help would be awesome.
Modified by BALLIN H22 EK at 7:01 PM 3/11/2006
Old Feb 12, 2006 | 02:27 PM
The Weather Man's Avatar
Haha. Did you do a 6k launch dumping the clutch?..........
Is it hard to shift in 4th or any other gear?
Old Feb 12, 2006 | 02:42 PM
Default Re: (TheKINGPin)
i didnt really rev it up just took off normal then got on the gas took it to the redline then tried to to shift into 2nd and it wouldnt go in...
1st and 2nd are the hardest to get in gear. 3rd,4th and 5th u just have to use force and grind sometimes...
Old Feb 12, 2006 | 03:04 PM
SteveoBA8's Avatar
Default Re: (BALLIN H22 EK)
try bleeding your clutch system again
Old Feb 12, 2006 | 03:44 PM
Default Re: (SteveoBA8)
alreaaady did still the same problem......
Old Feb 12, 2006 | 04:38 PM
Default Re: another clutch problem (BALLIN H22 EK)
also when at a stop put the clutch in and put in any gear the tranny makes a weird noise like a flapping noise.... i think the clutch isnt engaging all the way.. does that mean i need a new one?
Old Feb 12, 2006 | 05:52 PM
anybody had same problems? anyone know/think of what if might be? should i pull tranny and see if anything is fucked up?
Old Feb 13, 2006 | 03:59 PM
bump...............
Old Feb 13, 2006 | 04:39 PM
Default Re: another clutch problem (silverlude15)
yeap i think this is it.. there was fluid on the little rod and all around it and i looked in the engine bay at the master cylinder and i could see where fluid had leeked out there too... thanxx guy hopefully this will fix the problem
Old Feb 13, 2006 | 06:32 PM
Honda Sport's Avatar
could be a problem with the shift linkage. when mine's went bad, I had a very hard time getting the car into any gear. replaced the shift linkage and all was gravy.
Old Feb 13, 2006 | 06:40 PM
Default Re: (Honda Sport)
well ive replaced the shift cables before i guess ill take them off and look at them but i dont think this is the problem
Old Feb 13, 2006 | 06:43 PM
well hey does anyone know if i could use a integra clutch master cylinder instead of the civic one. and i got a H22 swap in my civic. or does it have to be the prelude one??
Old Feb 13, 2006 | 06:56 PM
SteveoBA8's Avatar
get a 98 civic hatch clutch master cylinder
Old Feb 16, 2006 | 07:47 PM
alright this is getting ****** annoying!!! i replaced my slave, replaced my master and still does nothing. the fluttering noise went away but it is still hard to get it into gear at high RPMs. if it was the cables wouldnt it be hard all the time and not just sometimes.... i guess the pressure plate clutch and throw out bearing are gettin changed next.. im gettin tired of this piece of ****. anyone wanna take it off my hand
Old Feb 17, 2006 | 07:10 AM
could be something damaged internal to the tranny.
Old Feb 17, 2006 | 10:44 AM
SteveoBA8's Avatar
Looks like you get to remove the tranny, i bet thats na uberbitch in a lil civic. Be patient and you will prevail.
Old Feb 17, 2006 | 10:52 AM
roller3804's Avatar
Default Re: another clutch problem (SteveoBA8)
Have you tried changin out the fluid in the tranny?
Old Feb 17, 2006 | 09:33 PM
Default Re: another clutch problem (roller3804)
well since the tranny was just replaced like a month ago i hope they put some new tranny fluid in it. but whatever just expletive it the car wouldnt even start up tonight im done with hondas
Old Feb 19, 2006 | 05:10 PM
bump for a gay car
Old Feb 19, 2006 | 05:13 PM
aw - man don't feel that way. If you switch to a chevy, you'll have problems day in and day out. Did you do the tests I told you to do? What were the results?
Old Feb 19, 2006 | 05:47 PM
no ima get a GTi most likely and go big turbo with that
Old Feb 19, 2006 | 05:48 PM
and i havent had time to mess with the car im at work
Old Feb 19, 2006 | 08:26 PM
aight as far as the tranny ill pull it off and replace the clutch pressure plate and throwout bearing as for the car not starting up.... i think its the coil cuz it turns over it just wont start. pulled a sparkplug and turned the key and no spark came out.... does that mean its the coil in the distributor???
Old Feb 20, 2006 | 10:01 AM
SteveoBA8's Avatar
Make sure your getting 12volts from the yellow/black wire in the 2 prong connector that goes to the dizzy.
Old Feb 20, 2006 | 03:42 PM
we checked each spark plug wire(pullin out wires and crankin to see if it sparked all did) disconnected the fuel line to see if the fuel had pressure( it did) bought a new dizzy rotor didnt do anything, sounds like it wants to start(backfiring but wont start. does it sound like the start is my problem?
