bore block
Old Feb 13, 2006 | 08:57 AM
kornerk12's Avatar
Default bore block
If i was going to do a larger bore what other upgrades would i need ? Obviously more fuel will be needed, larger pistons, larger rods, and new larger sleeves. Do i have to upgrade to a larger crank ? Also how will altering the bottom end affect the reliablity of the car ? And with a larger bore wont the motor need more air ... ? Would a port and polish do the job ?
Old Feb 13, 2006 | 02:01 PM
PrecisionH23a's Avatar
Default Re: bore block (kornerk12)
What exactly are you looking at doing? Answer that first.
Old Feb 13, 2006 | 02:34 PM
kornerk12's Avatar
Default Re: bore block (PrecisionH23a)
I want something that can be a weekend racecar but still be pretty reliable for my daily commute. I dont drive that much about 8k a year. I wanted to do an all motor setup, that being more reliable than a turbo setup for everyday. I was thinking of doing an rmf header, port and polish, obd -1 conversion, hondadata s300, worked head, not sure what pistons and rods yet.
I have a friend that works at a machine shop so labor will be very cheap.
Old Feb 13, 2006 | 02:42 PM
98TypeSH's Avatar
If you are going to go with forged pistons the block needs to be resleeved.
If you want to up the compression a little bit and stay OEM, go with some Type S pistons. Find a good shop to port and polish the head and to flowbench it. Maybe some stage 2 or 3 cams and matching valvetrain. From a budget standpoint, id say go turbo. resleeve, new pistons, rods, fresh rebuild basically. If tuned right and maintained, it should be pretty reliable. For around the same price, you could have three times the power out of a turbo setup.
I suggest you start doing alot of reading.
93delsolJDM
Feb 13, 2011 11:25 PM
JDM turbo DC
Nov 9, 2005 12:55 PM
b_jamin
Mar 19, 2004 02:55 AM
JICsube
Jan 18, 2003 11:42 AM
o.G.A.g.
Apr 1, 2002 03:19 PM
