pulling the head
Old Feb 11, 2006 | 04:44 PM
coreyfrenzel's Avatar
Default pulling the head
i am pulling the head off my h23 do to no compression in the #3 cyl. what is the quickest easiest way of pulling the head? thanks
Old Feb 11, 2006 | 05:25 PM
RJonathan's Avatar
Default Re: pulling the head (coreyfrenzel)
disconnect all sensor on the intake, unbolt the header from the head and pull it off. go under the car and take out the intake manifold braket. and make sure you unplug the sensor that connect to the little black box that is bolted to the bottom of your intake manifold. Then losen the tensor bolt for your timing belt. make sure you disconnect all coolent line. take off your valve cover, disassemble your head to remove the cams. then you can get to the head bolt, unbolt it and use a needle nose plyer and pull all the head bolt out. then grab a buddy. You and your buddy grab one side and lift it off.
lv6l
Aug 15, 2018 05:35 PM
Btothe3rdDegree
Jan 28, 2005 11:32 AM
SlowTeg
May 22, 2004 04:11 AM
leprechaun117
Feb 1, 2003 06:07 PM
integra6650
Jul 21, 2002 05:40 PM
