Axle issue
Old May 13, 2013 | 07:00 AM
Prudz_lude's Avatar
Default Axle issue
I'm having a bit of an axle issue that I need to resolve ASAP. The passenger side axle seats right, but sticks out of the spindle a few threads to far. It seems to be creating a small leak from the transaxle seal (tranny seal). I can also sometimes feel a small vibration in the steering wheel that I am assuming is coming from the axle. Suggestions? I have the proper axles in. I bought 2 new ones from Honda just to confirm they weren't incorrect the first time around (always good to have spares) and still the same issue. I have a dyno day coming up in a week. I need to make sure the issue is fixed before hand.
Old May 13, 2013 | 07:54 AM
tkarner03's Avatar
Default Re: Axle issue
make sure that the EDIT* MALE end is seated all the way in the tranny. they some times can be a bitch to get seated all the way.
Old May 13, 2013 | 08:25 AM
Prudz_lude's Avatar
It is fully seated. I've triple checked, hammered it on with a mallet to be sure. This is why I'm lost at what to do.
Old May 13, 2013 | 08:29 AM
Bouckaroo's Avatar
adam wheres your car at? if yOU like ill come over and have a look at it.
Old May 13, 2013 | 09:05 AM
tkarner03's Avatar
well, im lost now too. axles can be a pain but there usually fairly easy to fix.
have to tried taking them apart and looking inside the boot and how the bearings or whatever they are look?
Old May 13, 2013 | 10:32 AM
Prudz_lude's Avatar
I would but I don't need to. The axle I had in before I was going to, then I went to Honda and just bought an extra set, a) to check if I had the right one (which I do) b) to see if maybe the first axle I had in was damaged or extended or something (which it isn't). I'm feeling it's something with the bearing seat. That is all I can think of honestly. I'm going to a junkyard tomorrow and buying a used spindle just to test fit and see if that fixes it.
Old May 14, 2013 | 12:54 AM
holmesnmanny's Avatar
did this just start happening ? it's probably a bit dangerous if indeed the bearing has moved off the hub..who knows if that thing will try to slide off all the way
bmxkills
Jan 30, 2011 08:53 PM
CoolRedXylophone
10
Dec 15, 2009 03:17 PM
HGZ
May 5, 2005 09:01 AM
FormulaGSR
Oct 5, 2004 04:34 PM
ABK
Apr 8, 2004 08:48 AM
