my 94 si build
my 94 si build
I bought the car in may of 2012 to replace my jeep (money pit) and had all intentions of keeping it stock-ish until i found out my fiance was steppin out. kick the girl to the curve, the money starts piling up
was bone stock with the h23. well i missed vtec and my old h22 but wanted something "different"
Interior
-stock everything
-skunk2 shift ****
Exterior
-fresh paint
-oem mud flaps
-spoon style lip
Engine
-F20B
-Chipped P06
-Full exhaust
Suspension
-eibach ground controls
-unknown struts
Future mods
-5 lug conversion
-window tint (15% all around)
-accord rear lip
-new clutch
-eventually all motor build
now time for the pics
-The day i bought it
Interior
-stock everything
-skunk2 shift ****
Exterior
-fresh paint
-oem mud flaps
-spoon style lip
Engine
-F20B
-Chipped P06
-Full exhaust
Suspension
-unknown struts
Future mods
-5 lug conversion
-accord rear lip
-new clutch
Re: my 94 si build
The stock h23 only last me about a month before it bent a rod. i was completely crushed! unfortunately the car ending up sitting for a year. after getting rid of a $hittay fiance i got to work as soon as possible. i new i wanted vtec but just wasnt sure exactly what i wanted to go with. i had a h22 in my 92 and had no complaints but still wanted something different so i went with an F20B!! sure glad i did too!
let the picture roll
out with the old, in with the new!!
To make the F20b obd1 compatible i used the upper plenum, distributor, fuel rail, injectors, h23 harness, power steering pump and branket, ac compressor and a couple other little odd and ends from my h23 along with my h23 stock mounts.
Re: my 94 si build
NICE!!!! another 4th gen built. check my build out too.
Is that a blue top h22? also the hood risers, those are just the ones that you buy online from pwjdm. they fit on all hondas?
Re: my 94 si build
thanks bro! ill have to check it out. nah its the f20b sir t blue top. yeah i emailed them about them and they said will fit all hondas.
Re: my 94 si build
thanks. the guy bought it off of someone else for 3000$ he said. and he needed money quick because he knocked up his gf. so lol, I showed up with 1000$ when he was asking 2200$. his gf made him take it.
Re: my 94 si build
new carrier bearing and seal for my half shaft. they rarely go out but when they do itl cause a vibration, one very similiar to an axle going out. two upper balljoints, 2 drivers side axle and 1 passenger side axle later i finally figured out what was wrong. wouldnt say money wasted, just replaced alot of old parts sooner then i wanted to!
Re: my 94 si build
finally got around to changing out drivers side axle and carrier bearing. after replacing just about everything up front, she finally drives nice and smooth without any vibrations at all!
I know that they shouldnt look like this! that could explain some things
the half shaft with the new bearing on it. i didnt get any pics of the original bearing but it was pretty wasted.
Re: my 94 si build
This is awesome. Keep the step by steps coming. I'm the owner of the 1995 project on this forum and will be doing exactly what you are. I'm finishing up my interior and then will move on to suspension and bushings. After that I will be doing the H23 to H22 swap.
Your posts will make for a very good reference!
Re: my 94 si build
its really not as bad as some may think. i had everything off and torn apart in only 30 mins. when you start to tear into it and need to know anything feel free to ask! ive had mine in peices and put back together a couple times now. pretty much know my way around the entire car now!
Re: my 94 si build
have you looked into an h23 bluetop any? depending on what h22 your going for they can be a big upgrade in price but from what i heard a huge difference maker.
your builds coming along nicely too! got me suscribed!
Re: my 94 si build
http://www.jdmtigerjapanese.com/hond...ion-92-95.html
Currently I am looking into this engine and tranny. I have not done much research yet on engine types as i'm a long ways away from having to worry about that.
Re: my 94 si build
if you havent already check out hmotorsonline.com
you might be able to find what your looking for a lil cheaper, lol or not
Re: my 94 si build
haven't updated this in a while but haven't done to much except drive it, change out some wheel studs that got stripped out by a tech at dobbs and maxed out my coil sleeves, its kinda slammed I guess you could say . I will be starting a small wire tuck this weekend to try and clean up the bay a little bit and probably ordering a rear window visor for it as well this weekend. ill have some pics up once I get a chance here soon.
Re: my 94 si build
well, for being slammed around the high way from an 18 wheeler in the middle of a snow storm she doesnt look really all that bad but she'll be needing a new bumper, headlights and 1 corner marker, hood, fender, and just a tid bit of suspension work.
BUT my times in hondas and lowered cars may be coming to an end because of another accident i was in about 2 months ago. while with a friend an awesome drunk driver nodded off at the wheel and took his car, and my friends and drove us right into the middle barricade on 44, a main highway in stl and resulting in the driver getting a concusion and 3 cracked ribs while i recieved a concusion, dislocated hip, crushed lower vert in my back and a severely injured neck. i was told my neck was "as "broken" as it could be, without actually breaking." ive been out of work and pretty much bedrested for 2 months now with the exception of rehab and therapy. as much as i want to keep the lude, well driving it now just, hurts.
Re: my 94 si build
can you find out shipping to 63089? i have a pretty hefty settlement comin my way so depending on shipping i may hold out for a mugen front bumper or if everything goes as planned but it wouldnt hurt to have a spare sitting around, expecially the way my lucks been lately with cars.
