Does chipping save gas?
Old Jun 7, 2013 | 09:54 AM
LudeAct's Avatar
Default Does chipping save gas?
I'm thinking about chipping my prelude 96 si's p14 ecu, but not so much as to gain more performance, but to gain more mpg. I don't intend to drive hard at all as this is just my point a to point b. I would assume that a modified chip has a lot to do with leaning out the fuel curve throughout the rpm band, right? Therefore, if driven normally, I should see better mpg. Any input on this?
Old Jun 7, 2013 | 10:11 AM
cvcrcr99's Avatar
Default Re: Does chipping save gas?
Correct. Elementary school... or common sense gained in Elementary school taught me if you used less of something, you will use less.
You would want a wideband to monitor a/f's so you don't go too lean. Not worth the cost of a tuner, wideband, etc etc etc IMO
Old Jun 7, 2013 | 10:52 AM
LudeAct's Avatar
More like middle school, Lol. I didn't learn anything in elementary but I hear you though. Thanks.
Old Jun 7, 2013 | 11:56 AM
Sparksman's Avatar
A light foot will see better mpg gain then anything else. Google how to hyper mileage cars lol. Some yuppies take it to a whole another level. But you can gain another 10mpg if your dedicated. But its things like never use your brakes while turning and turn off your car at every red light lol...
Old Jun 7, 2013 | 12:29 PM
the171's Avatar
A completely stock honda is already pretty efficient. You cant lean it out much more than its set to run at cruising loads. The best way to get top mpg is to maintain the car (plugs, o2 sensor, oil, cap/rotor, tires, etc) and use a light foot.
Using an aftermarket ecu is for tuning an engine configuration that the car didnt originally come with. In this case you would tune cruising speeds to around 14ish to one air fuel ratio, using a wideband o2 sensor. "Chipped" ecus are old school, and regarded as not useful because you cannot guess how a modified car will run. It must be custom tuned using the tools mentioned.
Old Jun 7, 2013 | 12:38 PM
spens 91 Ef's Avatar
suprisingly simple aftermarket upgrades will raise mpg like headers
Old Jun 7, 2013 | 01:54 PM
98vtec's Avatar
moderator emeritus
chipping and running around on basemaps is unreliable. TUNING on the other hand is where gains and efficiency increase.
Old Jun 7, 2013 | 01:58 PM
LudeAct's Avatar
Headers? Interesting as I thought this would be completely opposite.
And as for tuning, from what I've researched I don't believe you can tune a p14 ecu, no?
Old Jun 7, 2013 | 02:31 PM
doood's Avatar
been there done that
you would have to convert to obd1 and use a socketed obd1 ecu
Old Jun 10, 2013 | 09:31 AM
why less restrictions and more efficent but can throw a o2 code, the cat system is to keep the earth green lol.
FULLYBUILT2.0
Dec 15, 2011 05:22 AM
JBLAZE622
Jun 15, 2009 02:06 PM
Commiecircusbear
50
Mar 29, 2008 09:23 AM
batboyvaj
Sep 22, 2007 05:09 AM
