5 lug conversion question
Old May 29, 2013 | 05:38 PM
preludeNApower's Avatar
Default 5 lug conversion question
Rear
Do I need to swap the spindle off the 5 gen onto here. This is a 4 gen knuckle with 5 gen hub/bearing. And you can see the nut does not thread down all te way
Also it seems my 4 gen axles do not fit in the 5 gen hubs
Old May 29, 2013 | 05:42 PM
tkarner03's Avatar
Default Re: 5 lug conversion question
are you a member on preludezone? i think i may have seen a write up on the 5 lug conversion not to long ago. if not i can try n do some digging for ya unless some one else gets around to it first.
Old May 29, 2013 | 06:09 PM
Found my answer to the rear... I need the 5 gen spindle.
As for axles in the front (I need new axles anyway) it seems like the 4gen axle does not even fit in the 5 gen hub.
Old May 30, 2013 | 02:06 AM
LatnKng's Avatar
Def doubt the spindles are the same..or the hub and axles. Always take into consideration the amount of splines hubs and axles have when doing swaps of this nature..the majority of the time they do not match up.
acidburn2k2
Aug 18, 2012 06:13 AM
Turbo R
May 1, 2009 04:10 PM
Jason-K
Mar 26, 2007 08:27 AM
