225 45 17 to wide?
Old May 13, 2008 | 10:32 AM
MyHotsh's Avatar
Default 225 45 17 to wide?
I have a 5th gen prelude with Tein SS Coilovers on 17in 5zigen rims. The tires on it now are 205 40 17s.
My question is can 225 45 17s fit my car without any rubbing in the front or rear? Anyone running this size tire on there 5th gen? PICS PLZ to see if they stick out to much.
I need to replace my tires and can get these 225s dirt cheap off my boss' son. I know i can raise the car so it wont rub the fender or quarter , but will it be to wide of a tire? I dont want my tires sticking out and looking stupid.
Thanks in advance..
SORRY if pic isnt working...
Old May 13, 2008 | 10:44 AM
subydoored's Avatar
Default Re: 225 45 17 to wide? (MyHotsh)
tires are not to big they are 3.71% bigger from your stock tire. depending of your offset it should rub.
Old May 13, 2008 | 11:22 AM
MyHotsh's Avatar
Default Re: 225 45 17 to wide? (subydoored)
Thanks for the info. I believe the offset on the wheels is 48..
So they're NOT to wide and they wont stick out to far?
Anyone have a pic of 225 45s on ther 5th gen?
Thanks again.
Old May 14, 2008 | 09:24 AM
GtechPro's Avatar
It will not be too wide, that I know for a fact. BUT the overall diameter of the tire will be increased and that may cause rubbing, along with throwing off your speedometer and slowing down your car a bit. I wouldn't go with that tire size on a Prelude.
Old May 14, 2008 | 03:14 PM
Simple_Sauce's Avatar
Default Re: 225 45 17 to wide? (GtechPro)
The rear will rub a lot. The front will rub under hard turns.
Old May 14, 2008 | 03:20 PM
shady_figure's Avatar
i run 215 45 16 on a 2.5in drop and there still seems to be some breathing room you should be fine
Old May 19, 2008 | 06:07 AM
MyHotsh's Avatar
Default Re: 225 45 17 to wide? (shady_figure)
Thanks for all your inputs, but i think im going to get them still and try them out.
Sh*t for the price of them i cant let them go. (4 bfg g-force sports almost new $100)
If im not happy i can just resell them..
He used them for about 2 months b4 he got rid of his car. They still have the little rubber hairs on the side walls.
Old May 19, 2008 | 10:32 AM
brandobot89's Avatar
both sides rub for me. the rears rub the rear bumper, but u can cut it off or sand it down to make it fit. the fronts rub for me also, but only when going up driveways or speed bumps. not sure of the offset, but i'm on aspec rsx rims.
Old May 19, 2008 | 11:16 AM
MyHotsh's Avatar
Default Re: 225 45 17 to wide? (brandobot89)
brandobot89, do you have any pics of the wheels on your car that i can look at?
Thanks.
Old May 20, 2008 | 03:12 PM
Fongman's Avatar
all 17 will rub if you have it lower
Old May 20, 2008 | 04:10 PM
MyHotsh's Avatar
Default Re: (Fongman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fongman &raquo;</TD></TR><TR><TD CLASS="quote">all 17 will rub if you have it lower</TD></TR></TABLE>
Not true! my car is lowerd on 17s already with 205 40 17 and NO rubbing @ all. Im just asking because im going with a wider tire 225 45 17.
Old May 20, 2008 | 07:53 PM
Default Re: (MyHotsh)
after cutting my rear bumper and fender liner in the front..the front only rubs under hard turns. but now i found out the rear is rubbing on the lower control arm on unsmooth roads..i guess i have to lower my car anyother way to fix the rubbing on the lower control arms?
Old May 22, 2008 | 08:24 PM
GtechPro's Avatar
225/45/17 IS TOO BIG.
Not only will that size offset your speedo and slow down your car, but it will also look retarded on there.
Old May 22, 2008 | 11:01 PM
Rubs like nuts.
Old May 24, 2008 | 02:46 PM
w1ngt's Avatar
Default Re: 225 45 17 to wide? (Simple_Sauce)
What do the tires rub on for you?
Old May 25, 2008 | 10:12 AM
crj_lll's Avatar
Default Re: 225 45 17 to wide? (w1ngt)
Anyone running or know anyone running 225 / 40 / 17? That keeps the overall diameter closer to stock. Few tire makers make this size but you can find it.
Old May 27, 2008 | 08:22 PM
Default Re: 225 45 17 to wide? (crj_lll)
if the tires are rubbing against my rear lower control arm, what can i do to fix this?
Old May 28, 2008 | 03:37 AM
DfwBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crj_lll &raquo;</TD></TR><TR><TD CLASS="quote">Anyone running or know anyone running 225 / 40 / 17? That keeps the overall diameter closer to stock. Few tire makers make this size but you can find it. </TD></TR></TABLE>
use the good ol tire calc http://www.miata.net/garage/tirecalc.html
Old May 30, 2008 | 04:52 PM
GtechPro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brandobot89 &raquo;</TD></TR><TR><TD CLASS="quote">if the tires are rubbing against my rear lower control arm, what can i do to fix this?</TD></TR></TABLE>
Make sure you got a correct wheels size/offset and tire size.
Old May 30, 2008 | 06:41 PM
prelude_93vtec's Avatar
If you are going to do this anyways, try rolling your fenders
brandobot89
Dec 13, 2008 06:50 AM
honda_andy
Nov 20, 2006 09:30 AM
dacosta
Aug 14, 2005 05:39 PM
azian21485
Jan 25, 2004 10:56 AM
spangler
May 22, 2002 09:53 AM
