ABS code
Old May 24, 2008 | 05:11 PM
paniaguae640's Avatar
Default ABS code
I have a 94 prelude si and I wanted to know what code I have been getting since I am new at reading the codes, thank you in advance.
Old May 24, 2008 | 05:41 PM
nemesis25's Avatar
Default Re: ABS code (paniaguae640)
It looks like a code 30.
Old May 24, 2008 | 05:49 PM
what would a code 30 be?
Old May 24, 2008 | 05:56 PM
nemesis25's Avatar
Default Re: (paniaguae640)
I'm sorry, I think it's actually code 3 cuz I'm looking at a manual right now and that's what it says. Code 3 has to do with your ABS pulsers.
Old May 24, 2008 | 05:57 PM
I somehow think it is code 1 because there has been articles about it on the internet but i dunno
Old May 24, 2008 | 06:06 PM
nemesis25's Avatar
Code 1 is pump motor over run. Which causes the ABS pump to run a little longer than usual.
Old May 24, 2008 | 06:11 PM
Hawkze_2.3's Avatar
Default Re: (nemesis25)
Yeah it looks like a code 1 to me also. Code 3 is like blip...blip...blip all in a row.
Old May 24, 2008 | 06:12 PM
does anyone know how to fix this problem or to test it?
Old May 24, 2008 | 06:28 PM
Hawkze_2.3's Avatar
Helms manual
I just went to go check my abs fluid and it is above the max line could this trigger anything?
Old May 24, 2008 | 06:29 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paniaguae640 &raquo;</TD></TR><TR><TD CLASS="quote">I just went to go check my abs fluid and it is above the max line could this trigger anything?</TD></TR></TABLE>
No. You mean your brake fluid right?
Old May 24, 2008 | 06:30 PM
yeah but you have to put brake fluid in three places and i did not want to confuse anyone, so i just said abs fluid.
Old May 24, 2008 | 06:40 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paniaguae640 &raquo;</TD></TR><TR><TD CLASS="quote">yeah but you have to put brake fluid in three places and i did not want to confuse anyone, so i just said abs fluid.</TD></TR></TABLE>
Oh right, the reservoir on top of the ABS unit? I forgot about that one
Old May 24, 2008 | 07:16 PM
this ABS thing is confusing, I just came back from taking out brake fluid from the abs reservoir and still no dice. Do you think by changing the brake fluid to new fluid it will fix it?
Old May 24, 2008 | 07:17 PM
92hondalude's Avatar
Default Re: (Hawkze_2.3)
some of us still have abs <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
Oh right, the reservoir on top of the ABS unit? I forgot about that one </TD></TR></TABLE>
Old May 24, 2008 | 07:58 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paniaguae640 &raquo;</TD></TR><TR><TD CLASS="quote">this ABS thing is confusing, I just came back from taking out brake fluid from the abs reservoir and still no dice. Do you think by changing the brake fluid to new fluid it will fix it?</TD></TR></TABLE>
Uh, taking it out of the reservoir won't do anything. Your problems could be caused by air in the system or dirty fluid. Brake fluid absorbs moisture and does go bad over time...I changed some on our Chevy a while back and it was BLACK after the 9-10 years it had been in use.
I would either get a Helms manual and follow the procedures in there or have a good shop do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude &raquo;</TD></TR><TR><TD CLASS="quote">some of us still have abs</TD></TR></TABLE>
Hehe
Old May 24, 2008 | 08:01 PM
sorry about this but how would air get into the abs reservoir? And for some reason the fluid looks clean.
Old May 24, 2008 | 08:03 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paniaguae640 &raquo;</TD></TR><TR><TD CLASS="quote">sorry about this but how would air get into the abs reservoir? And for some reason the fluid looks clean.</TD></TR></TABLE>
You're right it's very unlikely, but stranger things have happened
Old May 24, 2008 | 08:04 PM
you can't see moisture, correct?
Old May 24, 2008 | 08:11 PM
LudeyKrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paniaguae640 &raquo;</TD></TR><TR><TD CLASS="quote">you can't see moisture, correct?</TD></TR></TABLE>
Nope. It's absorbed by the fluid. Both are generally clear.
Old May 25, 2008 | 04:53 AM
vlang29's Avatar
brake fluid turns dark with moisture. If your brake fluid is dark, and not relatively clear like new, REPLACE IT.
Water reduces the boiling point of the brake fluid, and if it gets low enough and boils..... good luck stopping
Old May 27, 2008 | 12:35 PM
I would get the helm's at kragen, right?
Old May 27, 2008 | 01:42 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paniaguae640 &raquo;</TD></TR><TR><TD CLASS="quote">I would get the helm's at kragen, right?</TD></TR></TABLE>
Not likely, you will only find crappy Haynes/Chiltons at local auto parts stores.
Get a Helms from helminc.com or eBay.
Alcatrax30
May 7, 2015 01:36 PM
serjey15
Feb 6, 2011 08:11 PM
arren123
Jun 18, 2007 04:00 AM
fassassin
Jan 8, 2005 05:17 PM
