TB SIZE
Old May 19, 2008 | 05:16 PM
hondalove888's Avatar
Default TB SIZE
I have purchased the skunk 2 pro series IM and it has a 66mm tb opening so would it be adventageous to me to purchase the 66mm Skunk 2 tb to accompany the 66mm opening on the manfiold? i belive stock tb is 60..?? has anyone gone with the 66mm ?? anything good?
Old May 19, 2008 | 07:47 PM
Acidcrakker's Avatar
Default Re: TB SIZE (hondalove888)
Well I hope you plan on tuning the car. It would probally make sense to use a 66mm TB on that IM.
You are having it tuned in some way right. Other wise, you might have the reverse effect and start loosing power.
Old May 19, 2008 | 09:24 PM
Hawkze_2.3's Avatar
A larger TB is going to make the gas pedal more sensitive and provide more airflow at higher rpms (providing that you need it )
Old May 20, 2008 | 05:18 AM
yup i realize how the TB works for the most part...im going to unfortuneatlly only be tuning it with a wideband because no dyno around my town...i have the neo for tuning which is a glorified vafcII...umm im just curious if anyone has gone with the 66mm 66mm match up ?
Old May 20, 2008 | 05:23 AM
Default Re: (hondalove888)
Well Ill be doing a 64mm TB and Plenum to my lude once I get my timing adjusted. And Ive been tuning with an Adjustable FPR. It pretty cool.
Old May 20, 2008 | 06:24 AM
sick bud... im running I/HytechHeader/exhaust/pulleys/IM and now this TB.....should i be upgrading fuel now such as injectors or fuel rail or keep it stock?
Old May 20, 2008 | 06:41 AM
Id say a slightly larger injectors cause you have the capability of more air now.
Im running, 375cc injectors on mine
Old May 20, 2008 | 08:45 AM
Kasakuto's Avatar
Default Re: (Acidcrakker)
375 CC is just perfect
porter
Jan 9, 2007 03:27 PM
kungfuSiR
Dec 1, 2002 01:45 PM
