Clutch Problems
Old May 18, 2008 | 09:14 PM
meszij88's Avatar
Default Clutch Problems
i have a 92 accord with an 94 H22 i recently came across some clutch problems. it started when i raced some civic on the side of the road i launched my car at 3200rpms and everything was fine....on the way home i felt as if i had to press the clutch farther into the ground for it to engage. it later blew out on me. my mechanic says it was the clutch master cyclinder. i replaced it and now im have a hard time shifting into 1st and reverse. not only that but clutch feels as if it's doin the opposite, i have to release it higher off the ground in order for it to engage.
not only that but the car idles at 2500-3200 rpms. when the car is in first gear, i let go of the throttle and it doesnt lower the idle the car keeps moving.
im confused. i have adjustable aem cam gears and an aem fuel pressure regulater. the regulater reads @ 50 psi right now can that be the problem.
Old May 18, 2008 | 09:16 PM
Hawkze_2.3's Avatar
Default Re: Clutch Problems (meszij88)
No those bolt on parts won't change anything unless they are installed incorrectly. Please read the Prelude FAQs at the top of the page and then if you still have questions try the search feature.
Don't race your car anymore if you can't fix it
Old May 19, 2008 | 08:37 PM
preludeboybmw's Avatar
might have been a slave cylinder or ur pedal needs to be adjusted , and check for vacuumm hoses unplugged
Old May 19, 2008 | 08:47 PM
tommy1387's Avatar
srry man but i think you might have wasted some money.. i sounds like a slave cylinder went out on you and they somehow patched it up and adjusted your pedal......
Alope
Jun 10, 2014 06:56 AM
92sully
Sep 17, 2010 08:19 AM
93civcx
Jun 18, 2004 06:25 AM
red96
Oct 21, 2002 10:50 AM
tinter
Jul 19, 2001 01:06 PM
