header
Old May 15, 2008 | 01:48 PM
eglude's Avatar
Default header
hi guys, im new to the prelude world and i have a question. i bought a megan header for my 2000 prelude and i want to know if its easy to install or take it somehere to get it done? or if someone can help me with a link on how to do it with pics would be great. thx in advance
Old May 15, 2008 | 01:58 PM
Saosinx's Avatar
Default Re: header (eglude)
i think that changing a header is one of the easiest things to do. only thing i can tell you is to get some pb blaster or some liquid wrench and start spraying the studs a few days to a week before hand, on a daily basis. the studs on the exhaust manifold, the studs connecting the header to the cat and the studs that connect the y pipe (remove the exhaust manifold if it's on there). just do spray it down once a day and it'll make the job go so much faster. might not be able to get under the car to spray the cat bolts, but if you can, do it! that is my only complaint about doing it. tools are very simple too. just a good ratchet set and a nice extension to get up to the y pipe bolts.
Old May 15, 2008 | 02:12 PM
eglude's Avatar
Default Re: header (Saosinx)
right on, good looking out. so the header will just bolt right up? no need to modify anything?
Old May 15, 2008 | 02:23 PM
smokedyou19's Avatar
no need to modify
Old May 15, 2008 | 02:40 PM
eglude's Avatar
Default Re: header (smokedyou19)
ok, ill atempt it this weekend. thanks
Old May 25, 2008 | 10:49 AM
eglude's Avatar
ok i got my header in, it was a b@#$h if you have no patients like me and want to do it right away (YOU NEED TO SOAK IT WITH WD40 FIRST, FOR A WHILE!!! TRUST ME) my question is, my hand prints stayed on and now it looks ugly and it looks as if it were to peel off of something, is there a way to take that off? is it bad to leave it like that?
Old May 25, 2008 | 11:55 AM
Kool-Lude's Avatar
I use rubbing alcohol. But you have to clean it BEFORE running the motor...afterwards is too late.
WD40 is not the best for breaking bolts free. Next time use a penetrant like PB Blaster or Liquid Wrench.
Modified by Kool-Lude at 1:10 PM 5/25/2008
Old May 25, 2008 | 03:43 PM
eglude's Avatar
Default Re: header (Kool-Lude)
damn, i guess its too late then, its looks kinda ugly now
Old May 26, 2008 | 06:52 PM
Saosinx's Avatar
just pull the header back off, get some header wrap, and wrap it. won't ever notice the finger prints in there again, and will help lower your engine bay temps.
Old May 26, 2008 | 07:50 PM
Prudz_lude's Avatar
yah i you should have wiped it down before you fired it up. Too bad for you i guess
Old May 27, 2008 | 04:21 AM
gibsanez's Avatar
header wraps are really hard on headers. Hold too much heat in the metal, and they will fail prematuraly.
No, they don't hold moisture.
HondaHeddie
Apr 10, 2006 01:00 PM
ckyskater733
Jun 15, 2005 02:45 PM
phenom3030
Dec 26, 2004 09:20 AM
Train
Mar 13, 2004 04:35 PM
subtleluck
May 31, 2003 01:20 PM
