h22 problems
Old May 17, 2008 | 02:25 PM
stevo11811's Avatar
Default h22 problems
92 jdm h22a, 70k miles..... just cant figure out what is causing my problem now..... was wondering if anyone can point me in the right direction... car drives fine, and will idles fine at times, and then all of the sudden the idles gets loopy and the car has trouble starting, sometimes wont start at all until cold, ive replaced the fuel pump relay, even soldered it, and tested voltage, ive never been able to check the pressure when it happens unfortunately, anyone think this could be fuel related or somewhere else?
Old May 17, 2008 | 03:27 PM
Acidcrakker's Avatar
Default Re: h22 problems (stevo11811)
So you have an Idle serge problem and cold start problem?
Old May 17, 2008 | 04:14 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevo11811 &raquo;</TD></TR><TR><TD CLASS="quote">92 jdm h22a, 70k miles..... just cant figure out what is causing my problem now..... was wondering if anyone can point me in the right direction... car drives fine, and will idles fine at times, and then all of the sudden the idles gets loopy and the car has trouble starting, sometimes wont start at all until cold, ive replaced the fuel pump relay, even soldered it, and tested voltage, ive never been able to check the pressure when it happens unfortunately, anyone think this could be fuel related or somewhere else?</TD></TR></TABLE>
What distributor do you have on the car? OEM?
I'd try swapping out the coil (it's external coil, right?) and ignitor in the distributor with known-working units. I had a distributor once (not OEM) that caused the car to stop running when it warmed up, after about 10 minutes on track.
-Chris
Old May 17, 2008 | 10:11 PM
boostdlude's Avatar
it sounds like ignition problem. mostly likely coil or distributor.
Old May 18, 2008 | 07:00 AM
Saosinx's Avatar
Default Re: h22 problems (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
-Chris</TD></TR></TABLE>
distributor king?
Old May 18, 2008 | 07:36 AM
Chris F's Avatar
Default Re: h22 problems (Saosinx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Saosinx &raquo;</TD></TR><TR><TD CLASS="quote">
distributor king?</TD></TR></TABLE>
yeah.
Old May 21, 2008 | 10:16 AM
Saosinx's Avatar
friend bought a dizzy from them for his d16 turbo civic and it did the EXACT same thing, so he had to go back to OEM. stay oem with the dizzys.
mitchell_2kSiR
Dec 13, 2008 05:16 PM
mitchell_2kSiR
Dec 5, 2008 11:46 AM
admedlin
Nov 3, 2006 02:58 AM
acmeotally
Aug 11, 2005 04:29 PM
