car dieing due to turning on accessories
Old 05-12-2008, 07:28 PM
vthondaboi's Avatar
Default car dieing due to turning on accessories
Ok my car's RPM drops a couple hundred whenever the lights or A/c is switched on. At a complete stop it's fine.
But while driving then hitting the clutch and letting it coast it will die. It doesn't shake like a stall. You don't realize the car dies until you try to hit the gas or steer.
I don't believe it's a coincidence as I can make it die fairly quickly after turing on lights or a/c.
Any ideas guys?
Old 05-13-2008, 10:48 AM
Do it right the first second time!
Chief Brody's Avatar
Default Re: car dieing due to turning on accessories (vthondaboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vthondaboi &raquo;</TD></TR><TR><TD CLASS="quote">I can make it die fairly quickly after turing on lights or a/c.
Any ideas guys?</TD></TR></TABLE>
Get the battery and the alternator tested.
Old 05-13-2008, 11:01 AM
vthondaboi's Avatar
replaced the battery and the alternator tested out good
mechanic shop said it was a bad compressor fan or something, not sure how that would affect the lights too though but we'll see
Old 05-13-2008, 06:01 PM
gstrudler's Avatar
Default Re: (vthondaboi)
Sounds possibly like a short somewhere. Not sure why it wouldn't die at idle, though. I'm curious too because recently my car just died on the freeway; didn't even realize it had until I went to put on some gas and then realized it was dead. Now I can't get it to turn over and my battery is draining. However, I had the battery and alternator tested today and both were fine, but I'm getting some voltage to the negative battery clamp even when it's disconnected from the battery.
firefighter509
Acura TL, RL & ZDX
09-28-2011 02:36 PM
Boosted EJ2
02-06-2011 11:43 AM
meangreenEG
30
07-05-2007 08:56 AM
dmxsoulja3
12
12-24-2004 11:55 AM
7808
12
06-06-2004 02:46 AM
Quick Reply: car dieing due to turning on accessories
